586,104 active members*
3,324 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Calculating work zero
    Jun 2008
    113
    The P-200M control allows expressions in numeric fields, so when calculating zero X to the center of a workpiece which has a width of 200mm,
    - first I touch the left edge and set X to zero
    - then I touch the right edge and input 200/2
    The question is, is there a more convenient way of typing the "200/2" like "X/2" or something similar? If the width was 1753.635mm, and I had to type 1753.635/2, the possibility of mistyping a digit is a lot bigger than if I typed just X/2?
    Thank you for an answer, if you got what I meant.
    Jun 2015
    4154
    Re: Calculating work zero
    hy / try vwkbx/2
    look : http://www.cnczone.com/forums/okuma/...ontroller.html
    kindly !
    ps : far as i know from teahole and from a p200manual, those vwk variables should work on p200
    ps2 : please be aware, that those variables may work inside the program, but may not work inside the input fields :
    ... for example you may push SET, input 0.1, enter
    ... but you may receive an error if you push SET, input vwk**, enter
    Jun 2015
    4154
    - first I touch the left edge and ...
    stop right there instead of moving the cnc, just bring the table in front of you, measure with a caliber
    X axis should still be where it was
    and so, input :
    ... X_origin=CALL
    ... X_origin : ADD lenght/2
    for short parts, with normal tolerances, should be faster kindly !
    ps : i guess there is CALL on osp 200
    ps2 : G92 X-length/2 ?
    Jun 2015
    4154
    the manual of p200 has explanations for bougth CALL and G92 .... you are welcome kindly !
  1. Calculating Width of Cut
    By ex-egll in forum PCB milling
    Last Post: 02-23-2013, 04:43 PM
  2. Formula for calculating RPM?
    By SSfab in forum Mechanical Calculations/Engineering Design
    Last Post: 07-18-2012, 03:28 AM
  3. calculating????
    By cd2 in forum Solidworks
    Last Post: 03-22-2011, 03:24 AM
  4. Help calculating load on a nut
    By Brenck in forum Mechanical Calculations/Engineering Design
    Last Post: 05-04-2009, 04:29 PM
  5. Need help on calculating steps
    By rustamd in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2007, 01:08 PM
