586,114 active members*
3,287 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > hitachi seiki spindle wont turn on
    Apr 2013
    24
    Hi all,
    I was recently trying to install a LNS Quick load bar feeder on Hitachi seiki TS15 lathe with seicos control. I have a few different diagrams that show the wiring a slightly different way. I could not get the lathe to see the bar feeder was ready or the bar feeder to see that the lathe was ready.
    However, I gave up so I could make some parts, disconnected the bar feeder wiring and replaced the jumpers so the lathe would not alarm out from no signal from the bar feeder. Now the spindle wont turn on either with a program or in MDI mode. I can change gears and if I turn it by hand it will read the RPM its turning on the display. If I command an S1000 M3 like I normally would it accepts it but doesn't turn on and eventually gives a cycle time out error on the display.
    If I look at the input/output diagnostics it doesn't seem to change the "0" or "1" when I clamp or unclamp the chuck. It does however physically clamp and unclamp and the appropriate LED on the SLAVE board lights up when clamped or unclamped.
    Looking at the input/outputs it looks like the emergency stop is on regarding the spindle, however not sure if its supposed to be a "0" or "1." Its set to "1" currently. However there are no other signs that the emergency stop is on. I can index the turret and move all axis and everything else.
    I did command a M16 when playing with the bar feeder which for this lathe is "bar feeder on." I have commanded an M17 which is "bar feeder off" which has not fixed anything.
    The spindle drive doesn't show any error or alarm codes, just displaying "--" waiting for a signal.
    Thanks for any help anyone can give.
    Clinton
    Sep 2018
    15
    Are you solved problem
    Sent from my SM-G355H using Tapatalk
  1. Hitachi seiki ht turn 20r3
    By ironofeden in forum Hitachi Seikis
    Last Post: 02-27-2014, 03:23 PM
  2. 1986 Hitachi Seiki Hi-TEC TURN HT20
    By EricMFG in forum Hitachi Seikis
    Last Post: 12-10-2013, 04:57 AM
  3. HITACHI SEIKI HITEC-TURN 25S LATHE
    By mikeymgs in forum Community Club House
    Last Post: 09-27-2013, 08:48 PM
  4. Hitachi seiki Hitec turn Ht 20/25
    By rai in forum Fanuc
    Last Post: 09-22-2013, 12:13 PM
  5. Hitachi Seiki Hitec - Turn 20S Help
    By fboling in forum Hyundai Kia
    Last Post: 09-18-2012, 08:53 PM
