586,115 active members*
3,428 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor / ball screw stalling
Results 1 to 7 of 7
    Nov 2014
    12
    Hi all,
    I've got a slight issue with one of my axes and I was hoping to see if I could get some help here. Any advice would be greatly appreciated. I've got a problem where my stepper motor stalls. Current spikes up to about 1.5A and I hear a loud rattling, but the ball nut goes nowhere.
    A pic of my setup:
    http://www.cnczone.com/forums/attach...d=359902&stc=1
    http://www.cnczone.com/forums/attach...d=359904&stc=1
    Stepper motor info:
    Rated current: 1.7A
    Winding inductance: 3mH
    Rotor inertia: 51gcm^2
    Bench supply voltage: 24V
    Ball screw info:
    Diameter: 16mm
    Pitch: 5mm
    Software:
    Arduino + gShield running grbl 0.9
    From what I understand, a stepper motor with these specs should be able to drive this ball screw with no load rather easily.
    Things I've tried
    - Replacing the ball screw
    - Checking sections of the ball screw to see if there are sections with more friction (letting it stall and then manually rotating the screw to see if there are rough patches) - but there seems to be no consistent position where the ball nut gets stuck
    - Reducing feed speed (tried speeds ranging from 250mm/min to 500mm/min)
    - Loosening up the assembly (to give room for components to move around slightly in case of some over constraints)
    Not quite sure what to do here at this point.
    PS: please move if this is in the wrong sub.
    Feb 2017
    17
    Re: Stepper motor / ball screw stalling
    Quote Originally Posted by hpoon View Post
    Hi all,
    A pic of my setup:
    Stepper motor info:
    Rated current: 1.7A
    Ball screw info:
    Diameter: 16mm
    Pitch: 5mm
    Software:
    Things I've tried
    You probably need to adjust motor driver timings for parameters of step length, step space, direction hold and direction setup.
    Sent from my SM-G900V using Tapatalk
    Nov 2014
    12
    Since I'm using grbl, the only configuration values (https://github.com/grbl/grbl/wiki/Co...#grbl-settings) that I see are relevant are:
    - Step pulse, microseconds (10 microsec) - I played with this (tried like 100 microsec), but I'm not sure what to set it to for my driver (DRV8818)
    - Step idle delay, msec (25 millis) - Seems like a long time - I didn't mess with this
    - [X,Y,Z] steps/mm - 200 steps per rev * 2x microstepping / 5mm pitch = 80 - this setting I had already set and thought was all I needed
    - [X,Y,Z] Acceleration, mm/sec^2 (10 mm/s^2) - I tried setting this to 2.5 mm/s^2, which didn't help
    Thoughts?
    Feb 2016
    286
    Have you tried with the stepper unattached to the ballscrew?
    Nov 2014
    12
    Ahh good catch. I just tried it and it stalled the same way. I think you nailed the problem on the head. I tried running that stepper motor with nothing attached to it, and it makes a super loud noise as it runs and then stalls sometimes. I tried out a different motor and it ran smoothly and much quieter. I guess that stepper motor may as well be trash right now
    Thanks a lot!
    Feb 2017
    17
    Page 6 of the driver guide has the timings you need to translate.
    DRV8818 2.5A Bipolar Stepper Motor Driver with On-Chip 1/8 Microstepping Indexer (Step/Dir Ctrl) | TI.com
    For instance, your step pulse duration appears to be 1 microsecond.
    Jul 2016
    660
    The stepper motor on your picture is huge, if you want to use that kind of motor in an arduino shield, you need another driver on that motor with a separate power supply.
  1. Live stepper driving a dummy stepper, via timing belt, on dual ball-screw X axis?
    By Rees Guitars in forum DIY CNC Router Table Machines
    Last Post: 02-10-2014, 05:12 AM
  2. Stepper motor is stalling
    By bgolash in forum Stepper Motors / Drives
    Last Post: 04-11-2012, 01:31 AM
  3. Coupling stepper motor to ball screw
    By ahab8783 in forum Hobby Discussion
    Last Post: 09-14-2011, 09:19 PM
  4. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  5. Ball screw and Stepper Motor Size
    By ericdwilso in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 08:40 PM
