Hi all,
We have a new model breakout board coming out shortly with VFD support, so we are clearing out our current model below cost.
Normally $49.00 now only $4.90 Limited quantities remaining.
eBay Listing
This breakout has heavy duty 20A mains relays for Induction motors up to 3HP, coolant pumps etc. So if you have a Bridgeport or similar you are thinking of converting, this could be a good match.
Quick Start Guide included in the box. You can download a copy from here.
Connects up to four step/dir drives to Mach3 through a standard printer port.
Two 250VAC 20A heavy duty relays rated for switching inductive loads. (spindle motors, pumps etc)
Three general purpose optocoupled inputs. (touch probes etc)
E/Stop switch support.
Limit switch support.
Charge pump support.
IEEE-1284 compliant with buffers and termination on I/O lines. 5V signal levels.
On-board 32 bit ARM CPU provides enhanced safety interlock logic and digital signal conditioning
PCB dimensions 79mm x 79mm. Mounting holes 3mm on 72mm x 72mm square
These breakout boards are designed to complement our Servo drives, but are ideal for connecting up any Step/Dir stepper or servo to Mach3 via a parallel port.
Thanks for looking!
