586,082 active members*
3,602 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Used Fadal 4020A 1997, a lot of questions
    First of all, sorry for my English.
    I`m the "happy" owner of used Fadal 4020A machine. The workshop is located in Ukraine and the machine is from Germany.
    1) When I turned it on first time my reaction was "What?? Why the interface in deutsch? How I can switch to english?" The answer is "No way((". New board with english interface costs ~500$. For example on Fanuc 0mc control I switched from deutsch to english by changing one digit in the parameters.
    2) The second surprise was - no air, no oil in the waylube system and NO ANY AIR/OIL LEVEL ERRORS. I turned on the machine without air connected, without oil and machine starts fine, moved all axis, and have not any errors. Is it normal? Or maybe the previous owner done some "hacks" and disabled the air and oil level checking. According to the previous experience with haas, fanuc and heidenhain controls the machine have to check these levels.
    3) All the ballscrew is leaking. Fadal is the first machine I saw with ballscrew cooling system, it is redundant. I bypassed coolant tubes outside the thrust bearings blocks
    4) Axis motors accelerate and deaccelerate with some jerks. When I turn on the machine, push the green "cnc power" button I hear a couple of jerks. Looks like it appear when the power of axis amplifiers is turning on. During joging or program running the jerks appear when the motor starts, stops and changing the direction especcially rapid movement. I tried to adlust the gain and balance pots in the axis amplifiers according to maintenance manual, now motors run little better but jerks are still on. Maybe I will make the video a little bit later. The motors are brushless
    5) Jog mode is awkward. To move the axis I need choose the one by turning the switch, then press + or - to apply direction and then push jog button to move. Why Fadal has no separate buttons for x+ x- y+ y- z+ z- jogging. It is very convenient for probe moving, manual facing, simple part milling etc. It is the thing I used to working with fanuc, haas and heidenhain machines.
    5) There is not enough thrust to hold the tool... no, there is no thrust at all. The new CAT40 tool holder is swinging cw/ccw between spindle dogs. Belleville washer need replacement. Is the Fadal use the same washers in different spindles? My spindle is 7.5k with through tool coolant. I found next dimensions - OD - 1.235" ID - .647" Thickness - .077" Height - .110". Thanks god the washers is metric.
    6) Inch threads. In USA it is not the issue, but in europe... To replace any screw i have to order it from USA. Also all the electric parts have USA voltage (110V). Maybe it is one of the reasons why the Fadal machines are so cheap in EU
    Positive things: travel range is perfect for the outer machine dimensions, command line is very useful, interface is pretty simple even in deutsch, DNC working well. And the most positive thing is the detailed maintenance manual
    Apr 2016
    74
    Re: Used Fadal 4020A 1997, a lot of questions
    i cannot help you on your first question, but i cannot believe that that cannot be fixed at least with a software update.
    second someone had to "hacked the system for you not to get those alarms.
    third,fadal does have the cooling in the ball screw, i would have left that, can't hurt??
    fourth, fadal's do jerk when they do a cold start, i would check the thrust bearings.
    fifth, jog mode is strange, but that is the way they set it up, you can have the switch turned and move another way, it can be dangerous.
    bellville washers go out often on these, plan on that. we have five different ones, all use same washers.
    good luck!!
    Jan 2015
    417
    Heres a good place for parts Independent Technology Service boards motors ballscrews pretty much everything
    - - - Updated - - -
    And all the manuals http://itscnc.com/fadal+manuals.html
    Mar 2016
    40
    You will not get an air alarm. If you try to use something that needs air you will then get a click sound in the back and then the control will say waiting on air valve. The oil tank has a float and when it is low you should get an alarm on the screen that says check way lube. The float hooks into the 1100-2 board in the back.
    Yes you need new washers... plus get new retention clips for the drawbar springs. Makes a big difference in a locking drawbar. Should pull 1800-2000 with a force gauge. When you pull the drawbar you should deburr the inside lip of the drawbar where the pull stud goes in.
  1. Replies: 3
    Last Post: 05-05-2020, 03:38 AM
  2. 1997 Fadal VMC 15 to Mach 3 retrofit
    By mike^3 in forum Fadal
    Last Post: 05-03-2014, 12:46 AM
  3. HELP drip feeding a fadal 4020a using mastercam x2
    By DLIDGEY80 in forum Mastercam
    Last Post: 05-31-2012, 04:02 PM
  4. Replies: 3
    Last Post: 02-05-2012, 08:37 PM
  5. 1997 Fadal 6030 for sale
    By jrjoet in forum Fadal
    Last Post: 01-14-2008, 05:09 PM
