586,690 active members*
3,038 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > What Connector Do I Need?
    Aug 2015
    100
    Hi everyone!!
    I am looking to add a cooler to the door of my 01 Arrow 2 1250C. I want to tap into the fuse block next to the computer in the cabinet as it has some open fuses. They are a weird flat bullet type connector. I cannot seem to find it in the parts manual or online. I was hoping one of you guru's on here would know the connector. Thank you for your help!
    Dec 2013
    5717
    Re: What Connector Do I Need?
    They are called Ferrule Connectors
    Ferrules Terminals | Mouser
    The crimping tool is a bit pricy. search "Ferrule Connector crimp tool"
    Dec 2006
    584
    You should not connect the unit to the machine power. You should connect it to another outside power outlet to eliminate the interference of the unit turning on and off sending voltage spikes through the machine and control.
    This is a problem that our customers have encountered when adding additional coolers!
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Aug 2015
    100
    You think I will have a problem with just adding 4 fans? This is all it is. 2 fans on the inside and 2 on the outside. It is not a compressor or oil cooler. Just an air heat exchanger. I didnt think fans would make much of a problem as there should be fans inside the cabinet anyways. Also, what are those empty fuses for then?
    Mar 2008
    285
    Jordan, Using the wiring diagram stamped on the back plate of the machine x9120xxxxyyyy; look around page # 4; it will show you that F7 & F8 were for work lights that must have been removed at some time and were rated for 5 amps. Greg W. @ 859-534-4750
  1. OP connector sanyo denki servo PV drive - looking for connector
    By gm276 in forum Want To Buy...Need help!
    Last Post: 12-15-2018, 07:39 PM
  2. What is this connector?
    By vickson in forum Controller Cards
    Last Post: 06-21-2012, 09:26 AM
  3. JP5 connector
    By CAROLIVAR in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-26-2011, 09:32 AM
  4. connector???
    By xray34 in forum HURCO
    Last Post: 07-29-2011, 05:50 PM
  5. Anyone know the name of this connector?
    By h3ndrix in forum DNC Problems and Solutions
    Last Post: 09-19-2010, 09:21 PM
