586,043 active members*
3,731 visitors online*
    1000 sequence alarm
    I have MATSUURA ES450H, Fanic 18i and got this alarm.
    Try to turn the spindle.
    Spindle not turning.
    The alarm flush.
    What is this? Where to dig?
    Feb 2015
    161
    Re: 1000 sequence alarm
    Check A bits in status in PMC. Trace in ladder.
    Please more detailed from this part. Where is A bits?
    I can see the status. But don't see any bits. What to do?
    Feb 2015
    161
    A bits are alarm bits on PMC side. If any are on, then trace in ladder to find why it is on. Or consult MTB. I believe alarms in the 1000 range are MTB alarms, not FANUC alarms.
    The problem was solved.
    http://www.cnczone.com/forums/fanuc/...e-blocked.html
    Unblock pallet clamp/unclamp sendor, setting pallet parameters.
  1. Yasnac LX3 alarm 400 SEQUENCE ERROR (2)
    By Delw in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2017, 11:30 PM
  2. Alarm - 1000#1 (1stcus) sensor
    By fxcity in forum Fanuc
    Last Post: 02-02-2016, 01:59 PM
  3. Hardinge VMC 1000 alarm 1001
    By WTF in forum Bridgeport / Hardinge Mills
    Last Post: 09-16-2015, 06:15 PM
  4. Hardinge VMC 1000 with 409 alarm and SP1-12
    By texaswalleye in forum Controller & Computer Solutions
    Last Post: 07-18-2013, 02:57 PM
  5. Bridgeport XR-1000 Alarm
    By gil2602 in forum Bridgeport / Hardinge Mills
    Last Post: 09-06-2011, 11:04 PM
