586,067 active members*
5,340 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Will Fusion post the correct Gcode for a Multicam Router
    Apr 2016
    Question Will Fusion post the correct Gcode for a Multicam Router
    If anyone would be so kind to give me some in-site to see if I can post code correctly from fusion 360 that will run on my Multicam 1000 router. If not is there any other program I could possible use... Thanks
    Dec 2013
    5717
    Re: Will Fusion post the correct Gcode for a Multicam Router
    There is a Multicam post processor in Fusion 360, it should run your router. Autodesk CAM | Post Library
  1. Replies: 3
    Last Post: 04-22-2020, 05:09 PM
  2. Migrate Fusion 360 CAD/CAM to Multicam 3000
    By PeteMaui in forum Uncategorised CAM Discussion
    Last Post: 01-05-2016, 11:07 AM
  3. Replies: 14
    Last Post: 09-18-2011, 03:11 AM
  4. correct gcode ?
    By jezx in forum Canadian Club House
    Last Post: 02-17-2011, 03:17 AM
