586,051 active members*
3,590 visitors online*
Results 1 to 8 of 8
    Apr 2017
    6
    6040 cnc router issues
    Hi All,
    I recently acquired a 6040 cnc router. Unit is set up and cutting G10 glass very well but runs into 'issues' milling aluminium.
    Example..
    Cutting 6061 alloy, carbide tian 4mm end mill cutting out some shapes on 8mm stock.
    Symptom - say a square part 2 90 degree edges are vertical and the apposed are slightly tapered with visible steps for the first
    couple of passes. A bearing pocket starts out pretty well but gets more oval as the depth increases. Left side of hole vertical, right is tapered.
    Seems that the error is multiplied as the depth of slot increases. Most apparent on Y axis...
    Have trammed z axis to within a couple of thou (had to make adjuster). no missing steps or binding (that did take some work)
    Using correct feeds and speeds (calculator)
    looks like Y axis backlash but also see it on the X
    Using a dial indicator I can move the spindle +/- 10mm in X or Y and get no more the 2 to 3 thou backlash?
    There is something simple wrong here but I can see it??? (other than it is what it is..)
    Paul.
    Jul 2016
    660
    Re: 6040 cnc router issues
    can you post the actual cutting output of the product? what CAM software did you use? can you post the exact dimensions of the model? Im gonna try coding it my way then try it out on your machine, by the way im also cutting aluminum materials on custom products on a 6040, I cut 200 pcs. on it with no errors.
    I even cut triple clamps on a 6040
    Attached Thumbnails Attached Thumbnails 20170228_104103.jpg   20170302_170607.jpg
    Apr 2017
    6
    Thanks for the quick response KH0UJ
    I am using Autodesk Fusion 360 to create an STL (was using solid works but cant afford to purchase it). The cam processor is MeshCam that generates the gcode. I am machining small parts for a model helicopter.
    I'll take some photos tomorrow of the parts that display the symptoms well.
    Paul.
    Apr 2009
    5516
    Quote Originally Posted by paulsanders View Post
    Paul.
    If you have Fusion360 why are you using MeshCAM for g-code?! Use Fusion360!
    Apr 2017
    6
    Quote Originally Posted by louieatienza View Post
    Really? I initially bought Meshcam when using Solidworks.. had a fit of conscience and paid for autodesk, given it does everything I needed... perhaps it does more than I thought!
    Will have to have a play tonight.
    Paul.
    Apr 2017
    6
    The CAM in Fusion360 has made all the difference.. cutting parts in 1/4 of the time, getting a better finish because I can tune each step of the job.
    I did not think I could get this capability for under 400 bucks! I can see I have some backlash tuning to do but nothing major.
    Thanks all
    Apr 2017
    6
    Well, Fusion 360 cam is good but at the end of the day it appears the machine still has an issue.
    See the stepping in the Y axis.. most obvious with the adaptive clearing. Lower cuts are profile based.
    Where does one start????
    Apr 2017
    6
    I replaced the stepper cables with shielded 4 core. Terminated the shielding to the metal plug that goes into the controller.
    Sanded the paint from around the fittings on the case to get a good earth and then ran a star common ground to the vfd, controller, PC,
    router bed and my custom casing for the machine.
    FIXED!!
    I think the shielded cabling is what did the trick. Others have made this same mod to solve various problems. I found one thread
    that had the same symptom as mine by replacing the cables with shielded type.
  1. HY 6040 cnc router any comments, someone have it?
    By hlopezho in forum Chinese Machines
    Last Post: 05-24-2020, 08:08 PM
  2. 6040 router
    By flewggle in forum Chinese Machines
    Last Post: 01-28-2017, 04:33 AM
  3. Help with Chinese CNC 6040 Router Please
    By Wdbilbo in forum Chinese Machines
    Last Post: 12-18-2016, 09:31 PM
  4. Chinese 6040 CNC Router
    By ecope in forum Chinese Machines
    Last Post: 11-02-2015, 10:07 PM
  5. New 6040 router issues
    By Shadow3081 in forum Chinese Machines
    Last Post: 10-09-2012, 04:42 AM
