586,103 active members*
3,183 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Mills > Emco VMC 100 tool holder alternatives? Extend Y Axis?
    Aug 2014
    117
    Looking for an alternative to the overpriced $150+ holders. Can regular CAT/BT30 holders be turned down and a bearing added? Or the tool changer "wheel" be removed moving to something similar to the F1? Can adapters be made? I dont have the machine in front of me (friend has it 600 miles from me) so its hard for me to envision what could potentially be done.
    Can the Y axis be extended at all? As is they are extrmely limited. I know on the Chineese conversions people have managed to replace ball screws and or grind away at the base to gain another inch or two and at this short of a throw even 5" would be welcome.
    Thanks guys,
    Chris
    Re: Emco VMC 100 tool holder alternatives? Extend Y Axis?
    I've started modifying some BT30 holders to fit my PC Mill 125. Turning the flange off is quite a bit of work, especially if it's a quality holder with high hardness and case depth. The pull stud end must be shortened. And, I still need to make pullstuds. If you get holders for almost free, it's probably worth it. I mainly want ER25 and other holders that can't be purchased from Emco.
  1. EMCO F1P-CNC Tool Holder
    By ShuRugal in forum Want To Buy...Need help!
    Last Post: 05-18-2014, 04:55 PM
  2. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
  3. emco compact 5 - lathe tool holder series??
    By NoviceLatheMan in forum EMCO Lathe
    Last Post: 01-27-2011, 06:33 PM
  4. emco 5 CNC tool holder problem
    By sparkymike in forum EMCO Lathe
    Last Post: 05-06-2010, 07:23 PM
  5. tool holder alternatives?
    By multiplex in forum DIY CNC Router Table Machines
    Last Post: 12-12-2007, 11:02 PM
