Sorry for the title but im unsure how to word my problem
I have recently started using a CNC machine at work the company i work for bought a new machine sent 3 people on a 2 day course and expected them to come back with 10 years of knowledge, so we currently have a CNC machine with zero experienced staff running it, we have basicaly stumbled our way through after the 2 day day course.
Our boss wasnt happy with the corners on the text saying its too rounded, So i worked out a way out of getting round it but im hoping someone can suggest how i do all this in Alphacamm, i currently duplicate the letter in VCarve Pro then cut it up and leave a small line to put the tool on before the finish pass import it into alphacamm and add the tool paths (See pictures below)
Path 1 - 6mm tool leaving 0.2 stock
path 2 - 1.5mm tool to get into the tight corners at finish size
path 3 - 3mm tool to take to finish size and give a nice edge.
The reason i dont just add path 2 all the way round the letter is becasue the tools are very weak they snap very easy being only 1.5mm thick and it cuts the time down massivly as 1.5mm usually set to 3 passes
Im starting to look outside of my comfort zone and push my limits, iv been looking into adding all my paths to a tool path (like a group) so when i add my path its adds them all. but the current way i do this doesnt work as sometimes it decides to put path 2 inside the edge sometimes outisde the edge for the tight corners
Attached is 3 pics showing you my letter with the passes i have and you can see the small line i leave (same for any letter with a tight corner)
Any help greatly appriciated!
