586,082 active members*
3,566 visitors online*
    Oct 2013
    4
    Chiron fz12w error
    Hi everyone
    Recently we purchased used chiron fz12w with sinumerik 810m ga1 twin pallet german language
    My question is that i do not know how to change pallet is there any m code or special procedure for pallet changing
    2nd question when we type a command in automatic section or part programming , i write command and when i hit the enter button control freeze and do nothing
    I tried reorg commsnd to reorganize part program memory but also system freeze with the alarm "reorg activ" but anywhere i can use this enter button and give the command to control like overstore but freeze in mdi and part program section
    Thank you
    Aug 2009
    115
    Re: Chiron fz12w error
    Hello,
    The M function for the pallet changer is M71.
    Regards
    Thomas
    Jun 2014
    6
    I know it's several months later, but I just found this. There are codes for each pallet. M31 calls pallet 1 under the spindle and M32 calls pallet 2.
    Dec 2019
    12
    Quote Originally Posted by tld70 View Post
    Hello,
    Regards
    Thomas
    Hello,
    I have Chiron FZ12W that had PLC failure. I replaced PLC but now i dont have parameters for Pallet changer and tool changer. Can you maybe send me backup of your machine?
    Thank you, Milan.
    Aug 2009
    115
    Hi Milan
    can you provide a MachineNumber.
    Regards
    Thomas
  1. Chiron FZ12W High speed Siemens 810m error codes
    By efret in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 10-15-2022, 08:36 PM
  2. 1992 Chiron FZ12W
    By warrenb in forum For Sale Only
    Last Post: 04-03-2016, 01:40 AM
  3. Chiron FZ12W Tool does not clamp in spindle (HELP!!!)
    By cs_sas in forum DNC Problems and Solutions
    Last Post: 03-06-2015, 02:51 PM
  4. Chiron FZ12w Fanuc 21i
    By singist42 in forum Fanuc
    Last Post: 02-22-2014, 08:56 AM
