586,067 active members*
5,119 visitors online*
Results 1 to 8 of 8
    Feb 2006
    7063
    Automatic Oiler
    There was a thread here a while back discussing automatic oiling systems. Below is a thread showing what I've done for mine. It will be 100% automated, based on spindle on-time, with the quantity of oil being delivered to each oiling point during each cycle being software selectable, so no worries about over- or under-oiling any circuit(s). All the goofy (and unreliable) flow-control/check valves are eliminated, making the system very reliable.
    http://www.cnczone.com/forums/novako...tic-oiler.html
    Regards,
    Ray L.
    May 2010
    327
    Re: Automatic Oiler
    Thank you for sharing, Ray.
    WW
    Sep 2009
    624
    Re: Automatic Oiler
    Thanks!
    Jun 2014
    1780
    Re: Automatic Oiler
    I was thinking about a series of small solenoids on each of the oil lines each controlled by arduino in sequence, one at a time from a pressurized reservoir.
    I only have one that isnt performing so I just hand oil it each time, luckily its one that is easily accessible.
    mike sr
    Feb 2006
    7063
    Re: Automatic Oiler
    Quote Originally Posted by popspipes View Post
    That will work, but it's an expensive way to go (13 solenoid valves and 13 relays), but will take up a lot more space, and will have MANY more fittings and electrical connections, making for MANY more possible failures. I did that on my knee mill years ago, but this is a much better, simpler, easier solution, and for the last year the valve has worked flawlessly.
    I just got the new valve tested under oil pressure, then mounted on the machine and plumbed up. Works perfectly, and only one solenoid valve, and one relay.
    Regards,
    Ray L.
    Apr 2013
    1788
    Re: Automatic Oiler
    Using a progressive lubricator
    https://www.youtube.com/watch?v=-cW7d9qQIa0 and https://www.youtube.com/watch?v=U7UN1jmT7P8
    is somewhat appealing but is expensive and would be challenging to make.
    Jun 2012
    311
    Re: Automatic Oiler
    Quote Originally Posted by kstrauss View Post
    Seems the tiny passages would eventually clog up. I like the direct switching valve idea better. As long as the valve switches you will get lube to the all the circuits.
    Apr 2013
    1788
    Re: Automatic Oiler
    The volume of oil delivered is determined by the displacements of the pistons so there is no reason that the passages have to be particularly tiny. But I agree, Ray's approach is far better for home construction.
  1. Automatic Oiler
    By SCzEngrgGroup in forum Novakon
    Last Post: 03-02-2018, 04:43 PM
  2. Automatic Oiler for the 1100
    By RA-Bowtie in forum Tormach Personal CNC Mill
    Last Post: 03-01-2015, 08:14 PM
  3. Automatic oiler question
    By TarHeelTom in forum Bridgeport / Romi Lathes
    Last Post: 06-16-2010, 02:55 PM
  4. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
