586,033 active members*
3,598 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VR series machine, 5 axis tap cycle??
    Jun 2012
    125
    So we have three VR machines. We have a programmer that has tried to use the G155, G164, G174, and G184 tap cycles. None of them work. G174 and G184 move to position and do nothing else. G155 turns the spindle the wrong direction and goes to deep. G164 does the same as G155. Has anyone ever used this option on a VR machine?
    Mar 2014
    133
    Re: VR series machine, 5 axis tap cycle??
    Contact Haas Automation in Oxnard California. Ask for apps dept or choose the phone option of software related questions. Tell the guy your issue and they will help you solve your problem,
    Jun 2012
    125
    They tell me to call my local HFO.
    Mar 2014
    133
    Sounds like a control/software issue. You probably should get a tech in there. unfortunately if we tell you to try something it won't be covered under warranty that your HFO could provide you. Definitely sounds like a control issue
  1. Replies: 0
    Last Post: 02-02-2017, 04:08 AM
  2. Need a replacement Z Axis ball nut for a SF Series machine
    By rugbyal in forum Multicam Machines
    Last Post: 12-26-2014, 12:16 AM
  3. o-t series drilling cycle
    By Michael82 in forum Fanuc
    Last Post: 04-20-2008, 07:07 AM
