586,121 active members*
3,643 visitors online*
    Sep 2007
    28
    Siemens motor numbers
    Hopefully someone can assist with this particular question. I have searched the web and have been unable to find anything thus far so I figured I would post here and hopefully someone may have the knowledge to answer. I need to replace a siemens drive motor on a machine, the original unit was a 1FT6044-4AF71-4EH1 and was later replaced with a 1FT6044-4AF71-4EH6. I want to know what the difference in the two motors is since the only difference in the number is 4EH1 and 4EH6.
    Dec 2013
    5717
    Re: Siemens motor numbers
    Looks like the only difference is 1 = IP65 protection vs. 6 = IP68 protection. You new motor is better sealed, and will run underwater IP68 = Protected from total dust ingress. Protected from long term immersion up to a specified pressure. (1M)
    see page 6/12
    http://www1.siemens.cz/ad/current/co...07-2008_de.pdf
    Sep 2007
    28
    Its been a long week. I knew I was missing something earlier. There is one other thing different in the 2 numbers. In the second string one is a 4AF71 and the other is a 1AF71. Im looking but havent found wat that designation dictates yet.
    Dec 2013
    5717
    See page 6/6 for the 1AF71. Looks like it might be a shaft length difference, I just had time for a quick glance. You need to study the specs a bit.
  1. Drawing Numbers and Part Numbers
    By petesurrey in forum Uncategorised CAD Discussion
    Last Post: 08-20-2013, 10:12 AM
  2. siemens motor
    By eagleinc in forum Hardinge Lathes
    Last Post: 11-30-2011, 07:01 PM
  3. 9 lead 3ph AC motor no wire numbers?
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 09-27-2011, 03:13 PM
  4. Fanuc Motor Numbers
    By TR MFG in forum Fanuc
    Last Post: 10-27-2009, 04:19 PM
