machdrives.com announces the release of the new "BBB" breakout board with VFD support.
Specifically designed for use with Mach3 and Chinese air/water cooled spindle motors.
The VFD circuitry is fully opto-isolated to prevent noise from the inverter getting back into control circuitry.
A 32 Bit ARM processor accepts low frequency PWM data from Mach3 and issues a high frequency PWM signal to the analogue filter circuitry. Additionally the CPU calculates and applies compensation to ensure a highly linear relationship between PWM duty cycle and analogue output voltage.
A step-up DC-DC converter boosts the +10V reference input to ensure ample headroom for a full 0-100% speed range.
The analogue output stage has a low impedance buffer so the output voltage is unaffected by input impedance loading on the VFD.
The user manual also includes connection and configuration details for the popular Chinese HY inverters.
Download BBB User Manual (PDF 2MB)
  • 4 Axis support for Step/Dir servo and stepper drives.
  • VFD support. Both analogue 0-10V and PWM.
  • Standard LPT parallel port w/buffered I/O lines.
  • Charge pump or simple enable support.
  • E-Stop switch support.
  • Limit switch support, both mechanical and inductive proximity.
  • Four 250V 5A general purpose relays.
  • Three opto-isolated inputs for Touch probe etc.
  • 11 LED indicators to simplify setup.
  • Digital noise filtering on all control lines.
  • 32 bit ARM CPU with safety interlock logic.
  • Dimensions 93mm x 79mm x 19mm.
List price is AU $49.00 (approx US $37.00)
Attachment 360372
Attachment 360374
