586,430 active members*
4,043 visitors online*
    Oct 2007
    5
    Attaching dial indicator
    I have a CNC Taig mill, I got a Chinese dial indicator, the type with plunger... but its useless if you can't attach it. I have a vise setup and I would like to square it up. What to buy for attachment that will work on my Taig, I prefer to buy not make it as I usually cut plastic and don't have any metal stock to machine parts. I've googled for hours and searched Ebay but did not find anything. IF you post a link to the item I need that would be great.
    Re: Attaching dial indicator
    I keep a Taig lathe tool post mounted on the spindle housing (fits in the t slots) and use that to secure a dial test indicator holder (cam lock style with round stock mount not mag base). They are meant to mount in the spindle but the 1/4 inch tool post works well. You want the mini version of the holder though, think I got mine at little machine shop some time ago.
    Note: you probably want to use a dial test indicator rather than dial indicator for vise squaring.
    Oct 2007
    5
    Thanks, So a Dial test indicator is the pivot type instead of plunger, correct?
    May 2015
    686
    Yes, something like this.
    Attachment 360552
    They have a dovetail at the top and along the rear and usually come with a cylindrical mounting post that lets you mount it directly into the chuck on your mill.
    Rod Webster
    www.vehiclemods.net.au
  1. Dial indicator -advice?
    By Kalvin in forum Benchtop Machines
    Last Post: 04-04-2013, 01:09 PM
  2. Dial Indicator
    By hive8 in forum Benchtop Machines
    Last Post: 06-18-2012, 10:59 PM
  3. HS-1 Dial Indicator Recommendations
    By GaussianRule in forum Haas Mills
    Last Post: 04-09-2011, 12:32 AM
  4. I can use a drum dial as a dial indicator can't I?
    By slashmaster in forum Benchtop Machines
    Last Post: 11-03-2010, 06:10 AM
  5. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
