586,096 active members*
3,807 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Refurbishing my 1989 Bridgeport interact 720
    May 2006
    60
    Hello,
    I have been refurbishing my 1989 Bridgeport interact 720 and found 3 broken tool holders and 3 broken spring tool fingers, and was wanting to know if any one has any used parts for sale, or source for new ones.
    Want List:
    3 - BP 22381086 Spring tool finger
    3 - BP 22381071 Tool holder (BT40)
    Bryan
    May 2006
    60
    Re: Refurbishing my 1989 Bridgeport interact 720
    Update,
    Here is a picture showing the broken parts.
    Thanks, Bryan
    May 2006
    60
    Update,
    I may have found out how the ATC fingers were broken. I was testing the ATC, having it load a 5/8 end mill and then put it back and then load a 3" facing cutter. I had ran this programs about 4 times changing the spindle speed each time. It was working fine, then on loading facing tool it jammed about 3/4 of the way into the spindle. It looked like maybe the weight of the tool had it tipped at a slight angle downwards. (The sharp end pointing a little bit away from the spindle)
    I stopped the program, and tapped the tool holder with a 2x4 and it snapped into the holder and then I restarted the program, and it finish.
    Questions:
    1. What is the right thing to do, to resolve a tool holder jam like this? Is there a way to step backwards a step, in this case stopping the upwards pressure on the tool holder?
    2. Could this be caused by a lose chains in the ATC letting the fingers dangle a bit? If so, is there a way to tighten the chains?
    Thanks, Bryan
  1. bridgeport interact 412
    By generaloceanics in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2019, 05:29 AM
  2. 1989 Bridgeport Interact 1MK 2
    By BearMachine in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2017, 02:20 AM
  3. Bridgeport interact 412
    By diyengineer in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2014, 12:14 AM
  4. Bridgeport Interact 720
    By beemergb in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2013, 08:13 PM
  5. bridgeport interact 520
    By goodmancncgcode in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2013, 02:53 AM
