586,290 active members*
3,806 visitors online*
    May 2005
    90
    Erickson QC30 Lock Nut
    Hi all, I'm re-assembling the QC30 lock nut after cleaning it up, but I didn't see how the inner spring and pin are positioned. Can someone who has experience steer me right as whats the right configuration?
    1st config
    2nd config
    3rd config
    4th config
    Thanks!...Jay
    Sent from my iPhone using Tapatalk Pro
    Jay,
    What did you find out for the configuration#?
    I'm in the same boat. Pulled it apart to clean and only found a spring. After searching on the floor found the pin.
    Sven
    Does anyone know?
    15362
    Re: Erickson QC30 Lock Nut
    Quote Originally Posted by Jay Kyle View Post
    2nd config
    Thanks!...Jay
    2nd config is correct, they can work just fine without the spring and pin also, just have to do it up tight with the wrench
    Mactec54
    Thank you MacTech. I was leaning toward #2 based on the wear marks on the pieces.
    Thanks again!
    May 2005
    90
    Quote Originally Posted by SvenMjolnir View Post
    Thanks again!
    It’s been a while since i put it back together, but i do remember working my way through the lockup process to figure it out. Glad macTech’s got it figured
  1. Erickson QC30 Holders
    By 1875 in forum Want To Buy...Need help!
    Last Post: 02-17-2016, 06:39 AM
  2. 2UVR with Erickson QC30 spindle
    By zpsbob in forum Tree
    Last Post: 12-08-2015, 05:45 PM
  3. Boss 3 Conversion - Erickson QC30 Spindle Nut Parts
    By 1875 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2014, 11:20 PM
  4. Where to buy Erickson quick change QC30 Holders?
    By thomasfreedy in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2013, 06:18 AM
  5. New Erickson QC30 locknut setup
    Last Post: 08-16-2013, 10:35 PM
