586,119 active members*
3,586 visitors online*
    Aug 2005
    300
    Post Simulation error
    I am running v25. When trying to do a simulation I get the error message ( Simulation object loading error. No operation is defined ). What thing or things am I doing that would make the software throw this error code?
    Ernie
    Re: Simulation error
    That error indicates that you've loaded the simulation without generating any valid cutting paths, were cutting paths visible before you loaded the simulation?
    If you upload a problem file I can take a look,
    Regards,
    Nick
    Aug 2005
    300
    Nick,
    This setup is for milling 12 pieces in one fixture. I had a brain fart and drew the 12 pieces then selected countour on each one. I did'nt notice but there were small gaps in the path which were discovered after reading your reply. I then started over with 1 part and got it to simulate correctly then copied that 15 times. reran the simulation and it simulated correctly. Thanks so much for your tip.
    Ernie
    Ernie,
    It's good to hear you have it sorted, thanks for confirming the cause & fix, this does help folks who search for a solution at a later date,
    Regards,
    Nick
  1. Simulation error
    By Kimne in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-09-2014, 10:27 AM
  2. V25 Simulation Error
    By gerinipus in forum BobCad-Cam
    Last Post: 08-22-2013, 10:51 PM
  3. Simulation Error
    By seal1966 in forum BobCad-Cam
    Last Post: 08-15-2013, 07:25 PM
  4. simulation error- happens often but not always
    By hatchmar in forum BobCad-Cam
    Last Post: 07-11-2013, 09:21 PM
  5. error during simulation
    By danny_wine in forum UG NX
    Last Post: 07-03-2013, 09:25 PM
