586,105 active members*
3,320 visitors online*
    Mar 2014
    27
    Cut order of objects
    Before sending a job, are you able to tell VCP
    what the cutting order is in a given object(s)? See Pic
    or does it decide what to do.
    I work with Enroute 3/5 so Im use to that setup.
    The ordering they have is Rows / Columns / in~out / out~in / Manual
    I cannot do the trial because of XP and issues. Wont install even w/ SP3.
    Also when it is doing a pocket job, does it work its way through
    an area mid-way and then go to another area and so on like it's forgetting
    something and then finally finishes the job? Trying to avoid the
    almost 10x cost for Enroute.
    Sorry for the dopey Q, it's just one of those quirks when something
    is routing/engraving and the machine does its own thing unexpected.
    I'll try the VCP trial when I get to work but wont be till next week.
    Ronnie
    Re: Cut order of objects
    The simple answer, that there is no simple answer.
    You really need to play with the demo and see if it will do what you need.
    You do not get these options in V Carve Pro. The only option you get is the order that you select the vectors.
    I did a quick test to match your sample. The one on the left were all selected together. The one on the right were selected in order to match your sample.
    You'll probably find that this will depend on exactly what you are doing. If you are doing pockets with multiple areas, the best way might be to do them individually, rather than in one operation containing multiple pockets.
    Mar 2014
    27
    Question Re: Cut order of objects
    Hmmm... I thought I sent in a reply. Didnt go thru
    Anyways.. Thanks Gerry for clearing that up.
    I managed a Trial of VCP, now a few Q's if you or someone else may answer if poss.
    Not crazy for overall use of it, but again it's not Enroute.
    Would I be able to send "selected" layers separately? Say 3 files
    Like: 01_holes.crv 02_pocket.crv 03_cutout.crv
    Or is this one file?
    Sucks... I wont be getting my machine for a while so I dont know
    what to expect in the meantime.
    Thanks all
    I don't understand the question?
    Do you mean can you output separate g-code files?
    If so, you can select individual toolpaths and export them in any combination?
    If you're asking something else, can you clarify?
    Mar 2014
    27
    OK, well V-Carve isnt for me and I'll go the Enroute route.
    I can select any given toolpathed object and setup for output individually.
    It seems that the ToolPaths in VC are locked and send as a whole.
    Whereas I can go back into Enroute toolpath and change the depth to say
    on one object or add a Width cut to them. Everything is its own.
    So now I can use Enroute on multiple puters, im good. End of story and thanks for your help Ger21
  1. moving objects?
    By kasari in forum CamBam
    Last Post: 04-12-2010, 01:14 PM
  2. Can You Identify These Objects?
    By gd.marsh in forum Benchtop Machines
    Last Post: 03-09-2010, 06:59 PM
  3. Unwrapphing 3d objects
    By twitch5000 in forum Rhino 3D
    Last Post: 10-14-2008, 12:13 AM
  4. moving objects
    By bearracecars in forum Autodesk
    Last Post: 09-18-2007, 09:54 PM
  5. aligning two objects
    By erase42 in forum BobCad-Cam
    Last Post: 06-22-2006, 11:07 PM
