586,070 active members*
3,500 visitors online*
Thread: Engineer
    Feb 2007
    Engineer
    I have FlashCut as a retrofit on an old Bridgeport Boss 5.
    The setup was pretty easy. However, I'm having problems making sense of the Tool Length Offset.
    See ms it should be simple - The old Bridgeport Boss software are was pretty easy.
    Can anyone headed to some good examples. I seem to never know where a tool is going to go when I call it up in the program.
    Seems a silly question, but it sure has me baffled.
    Don
    Re: Engineer
    hopefully you figured it out, but here is what i have.
    measure tool length from the nose of the spindle to the end of the tool, enter that as the tool length. when it picks the tool it'll change the size.
    i have my touch probe measured and set as tool #100 , i pick that tool,, then i run GCODE to do the xyz program home using tool 100, then after that if i change a tool it'll correct the Z.
  1. engineer cad cam
    By EAP in forum Employment Opportunity
    Last Post: 03-19-2017, 11:19 AM
  2. engineer
    By racing92 in forum Post Processor Files
    Last Post: 01-15-2016, 02:48 PM
  3. Replies: 0
    Last Post: 10-21-2014, 03:03 PM
  4. In Need of an engineer!!!
    By modeltruckshop@ in forum Mechanical Calculations/Engineering Design
    Last Post: 07-28-2010, 09:20 PM
