586,094 active members*
4,071 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > 3d Finish toolpath leave slight mark
    Feb 2016
    22
    Hello
    I use Aspire 8.5 to milling out this,look at the picture and you will see 5 slight mark after 3d Finish,these slight mark should not be there.
    I wonder,What can be wrong ?
    Aspire software,Settings in Mach3 or CNC Router machine
    Feb 2009
    192
    Re: 3d Finish toolpath leave slight mark
    This looks like cutter deflection caused by the tool moving in opposite directions. Reduce your depth of cut on the finish pass and this effect will be reduced. This is a typical example of 'conventional' vs 'climb' cutting. There isn't anything wrong with your software or hardware, it's machining technique.
  1. Finish toolpath issues
    By JEST in forum Aspire
    Last Post: 11-04-2014, 09:41 AM
  2. Replies: 9
    Last Post: 12-17-2013, 06:56 PM
  3. V24 slight trouble with 3D toolpath
    By Ben S in forum BobCad-Cam
    Last Post: 11-11-2013, 10:36 PM
  4. Replies: 0
    Last Post: 10-14-2013, 09:04 AM
  5. Surface finish toolpath problem in X5
    By yenchen23 in forum Mastercam
    Last Post: 12-05-2011, 06:23 AM
