586,051 active members*
3,801 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > DIY EDM build question! (guide compatibility with wire and drill edm)
    Apr 2013
    10
    hello guys
    i will be doing diy edm build soon.
    it will be used to cut carbide
    only one axis design though, but it meets my needs
    i am currently gathering parts and decided to use RC circuit style with arduino feedback
    the problem is, it is such a small design, that using conventional diamond guides forces me to make it bigger.
    however, if i use edm drill guide, it is veryshort(>25mm), so it allows me to build the micro edm with small footprint
    would edm wire sizes ex)0.1mm, and 0.25mm fit into these?
    i know diamond guide sizes and such that, it is 5 microns bigger than the wire sizes.
    i am not too sure if edm drill guides are the same.
    i am aware drill edm are not diamond, usually ruby or ceramic, but for my application it is not too critical.
    please do share your experience with this situation
    thankyou
    Sep 2010
    72
    Re: DIY EDM build question! (guide compatibility with wire and drill edm)
    Not sure what components you are using, but the guides in our Drill-20 are about 20x larger than the guides in our Robofil and CUT wire-edm's.
    More than that, how do you intend to mount them so that you get proper flushing?
    Wire-edm guides and their mountings are designed for that.
    EDM-drill guides used in their place ... not so much.
    I'm sure you could make them work, but how well and for how long is open to debate.
    Apr 2013
    10
    since the guides for the drills are designed to be rod-like, my design allows it to be fixed easily with a grub screw. also, i've found this drill guide with length of 25mm only.
    so the only problem is whether say 0.1mm wire fits into 0.1mm drill guides. i do know that the wire's actual dimension is different from its specified size.
    so 0.1mm = 0.105mm
    so i thought there might be fitting problems.
    however, i just decided to use tensioned wire over several grooved bearings and final adjustment with two bolts, lol. i think this might actually work as the bolt threads are V shaped, and very easily replaceable and readjusted.
  1. Hiwin block and rail compatibility question
    By jboots in forum Linear and Rotary Motion
    Last Post: 04-21-2016, 06:07 AM
  2. Stepper Driver & Motor Compatibility Question
    By 3541greystone in forum Stepper Motors / Drives
    Last Post: 11-02-2013, 03:48 PM
  3. Drill Press Speed Guide, Band Saw Speed Guide
    By zerodegreec in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2009, 07:12 AM
  4. Compatibility question (newbie)
    By Jan-Roger in forum DIY CNC Router Table Machines
    Last Post: 10-07-2008, 02:21 PM
  5. wire way guide
    By LK LLoyd in forum CNC Wood Router Project Log
    Last Post: 04-27-2008, 05:24 AM
