586,108 active members*
3,139 visitors online*
Results 1 to 6 of 6
    Nov 2012
    27
    Timing/Belt pulleys...source?
    Needing a 10-15mm wide belt, center to center distance of 92-100MM (I can shim to get over 92MM) and a pulley ratio of 3:1 or 4:1 to drive my Z axis. Drive shaft is 8mm and the screw shaft is 10mm. As long as the pulleys are 8mm or smaller, I can drill to fit if the hub is big enough. I can fabricate to include an idler pulley if necessary, but....I'm having a time finding someone who
    Anyone got sources? (besides ebay and 6wks shipping)
    Re: Timing/Belt pulleys...source?
    Dec 2013
    5717
    I buy most of my power transmission stuff from these guys. http://www.ametric.com/
    May 2015
    70
    Try Motion Industries
    Quote Originally Posted by millerized View Post
    Apr 2009
    5516
    SDP/SI, Misumi...
    Nov 2012
    27
    B&B gets/got the first order. Ametric's catalog wasn't working for on this machine, so they got canned for the sale.
    I'm working on gearing next, 20deg PA and 16 DP just don't come from MalWart around here. Just as soon as I figure out the ratio.
    Well...cancel that. The one pulley won't be in stock until sometime in June. Looks like I try another vendor later this evening.
    Ebay is looking like the best bet delivery time wise.
  1. How to match Timing pulleys and timing belt? (noob question)
    By cdesantis01 in forum Linear and Rotary Motion
    Last Post: 02-10-2017, 01:27 AM
  2. Your process for determining the timing belt and pulleys
    By arvidj in forum Benchtop Machines
    Last Post: 01-06-2013, 03:17 AM
  3. Making my own timing belt pulleys - how?
    By damae in forum MetalWork Discussion
    Last Post: 08-01-2010, 04:51 PM
  4. Timing belt and pulleys
    By samakthachai in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-25-2007, 05:31 AM
