586,708 active members*
2,453 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > MILLTRONICS VM17 G32 Z HEIGHT ALIGNMENT WITH CAROUSEL CHANGES
    May 2017
    Help!
    I purchased a used VM17 and when the machine turns on, after the homing sequence, I go to do a tool change and the spindle height to match the carousel is off. It can be from a 1/4" to 3/4" high or low.
    I then have to go into F7 Parameters..... F4 Axis.... To "Tool Change" and adjust the Z# to move the spindle to the correct height. Anyone know of another setting in the machine I'm unaware of needing to be set to avoid this?
    The indicators for the Z limit switch shows it works. The value for Z is different after every homing cycle.
    In the words of Slim Pickens in Blazing Saddles, "I am deepressed..." Help!
    Nov 2013
    128
    Re: MILLTRONICS VM17 G32 Z HEIGHT ALIGNMENT WITH CAROUSEL CHANGES
    One of two things is going on, either your z home switch is on the verge of not making, or the z drive has been changed and someone didn't widen the marker pulse width in the drive. Check the pitch of your z screw, and make marks at where it happens to find it's home on the column, see if the marks aren't a consistent distance apart. consistent such as the same as one revolution of the screw, or sometimes two or three.
    May 2017
    Quote Originally Posted by allen mullis View Post
    Thanks Allen!
    I'll put it through testing Monday and see what transpires.
    Oct 2008
    427
    Also, check the home switch itself. Make sure it is not sticky with built-up gunk or clogged with chips. When the switch re-opens will affect the location when the axis makes the last change-of-direction to look for the marker pulse on the encoder.A sticky switch may not release reliably.
    During the Home Sequence, you want the last move the motor makes to be a half of a turn, as close as you can reasonably get, to give you the best chance of finding the marker at the same place in the travel.
    Nov 2010
    39
    I was having the same problem as well as homing issues turned out the drive was changed and marker pulse was not set correctly. I went through everything for over a year trying too figure it out.
  1. Milltronics VM17 x axis movement
    By plane captain in forum Milltronics
    Last Post: 09-10-2016, 03:40 AM
  2. Installing more memory Milltronics VM17
    Last Post: 04-27-2016, 10:37 AM
  3. Carousel height problem
    By TiaanK in forum Haas Mills
    Last Post: 05-11-2011, 11:22 AM
  4. VM17 alignment error
    By Dr Evil in forum Milltronics
    Last Post: 05-08-2011, 01:27 AM
  5. tool carousel alignment
    By rubino2112 in forum DNC Problems and Solutions
    Last Post: 12-27-2006, 07:26 PM
