586,119 active members*
3,531 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 "Cutting" option using MACH3 mill generic post wont post!!!!
    Aug 2016
    22
    Trying to drive my MACH3 CNC plasma machiine with Fusion360 "cutting" machining option. it gives me the lead in features i need. but when i try to post process it it fails???? I've posted many 3d adaptive clearing, engraving, slot, facing...................without issue. but the cutting wont work??????? below is what i get???? any help would be awesome.
    thanks
    Information: Configuration: Generic Mach3MillInformation: Vendor: Artsoft
    Information: Posting intermediate data to 'C:\Users\ricro\AppData\Local\Fusion 360 CAM\nc\logo1stplasma2.tap'
    Error: Failed to post process. See below for details.
    Code page changed to '1252 (ANSI - Latin I)'
    Start time: Friday, May 5, 2017 12:36:08 PM
    Code page changed to '20127 (US-ASCII)'
    Post processor engine: 4.2.1 41304
    Configuration path: C:\Users\ricro\AppData\Local\Autodesk\webdeploy\pr oduction\629757f22e01db34146388e207b7011b131e863a\ Applications\CAM360\Data\Posts\mach3mill.cps
    Include paths: C:\Users\ricro\AppData\Local\Autodesk\webdeploy\pr oduction\629757f22e01db34146388e207b7011b131e863a\ Applications\CAM360\Data\Posts
    Configuration modification date: Wednesday, March 1, 2017 10:30:22 PM
    Output path: C:\Users\ricro\AppData\Local\Fusion 360 CAM\nc\logo1stplasma2.tap
    Checksum of intermediate NC data: a3dbe41f38fba5ecb534157450c9331d
    Checksum of configuration: ce5fcda1268ea1ab0aeaf3d37040164e
    Vendor url: Newfangled Solutions » CNC Software Home of Mach3
    Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
    Generated by: Fusion 360 CAM 2.0.2995
    Error: Waterjet, laser, and plasma cutting toolpath is not supported by the post configuration.
    Error: Failed to invoke 'onOpen' in the post configuration.
    Error:
    Error: Failed to execute configuration.
    Stop time: Friday, May 5, 2017 12:36:08 PM
    Post processing failed.
    Feb 2009
    311
    Re: Fusion 360 "Cutting" option using MACH3 mill generic post wont post!!!!
    It looks like your post processor is not setup for plasma/laser cutting. I've never tried it myself so I can't really be of much help. If you don't get any answers here try posting over on the Fusion CAM forum.
    https://forums.autodesk.com/t5/compu...-cam/bd-p/2070
    C|
  1. Fusion 360 Generic Fadal Post Output
    By megacanam in forum Fadal
    Last Post: 09-25-2016, 07:25 AM
  2. Replies: 0
    Last Post: 02-04-2014, 02:06 AM
  3. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  4. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  5. Pimp "my" generic post for TNC530
    By Lazy in forum Post Processors for MC
    Last Post: 05-11-2011, 08:20 AM
