586,075 active members*
4,167 visitors online*
    Oct 2006
    17
    Monitor water cooling of spindle
    I need to write a Macro Pump ( I think) to monitor fluid flow from 2.2 KW water cooled spindle. ( I want to stop or pause machine if water flow is interrupted from the spindle). I have the circuit designed and constructed so that I get a True/False signal to one of the inputs of my BOB but I don't know how to use the info to stop the router.
    The Artsoft tutorial is fairly limited and I was hoping some one can direct me to a better (more advanced) tutorial on using scripts and macros in Mach3. If not perhaps a kind person could tell me how to do it.
    Re: Monitor water cooling of spindle
    Something like this:
    If IsActive(Input1) then
    DoOEMButton(1001)
    Save as Macropump.m1s in the proper macro folder, and enable macropump in general config.
    http://www.machsupport.com/wp-conten...o_Prog_Ref.pdf
    Mach3Wiki
    Oct 2006
    17
    Your a gentleman and a scholar thank you very much. Exactly what I was looking for especially the macro referance
    Cheers
  1. WATER COOLING SPINDLE 0-24000 rpm ??? is this possible?
    By luis81 in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2021, 05:38 PM
  2. Water cooling my spindle
    By johnnyt74 in forum DIY CNC Router Table Machines
    Last Post: 02-11-2017, 12:15 PM
  3. Spindle Cooling Water Connections
    By kolias in forum Chinese Machines
    Last Post: 10-26-2016, 04:32 AM
  4. Water cooling a 2.2kW spindle with cpu radiator ?
    By fuzzyz1 in forum DIY CNC Router Table Machines
    Last Post: 04-25-2016, 03:26 AM
  5. Spindle water cooling 101. The right way.
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2010, 05:20 AM
