586,525 active members*
3,234 visitors online*
Results 1 to 10 of 10
    Feb 2017
    5
    Salvagnini p2 ABS programming
    Hello,
    I´m have been operating and programming salvagnini p2 for 3 months. Now I would like to learn about ABS programming. I hope that someone could send me some program example to get started width ABS programming. I write my programs manually, not with Edit p4.
    Andy
    Dec 2016
    9
    Re: Salvagnini p2 ABS programming
    Quote Originally Posted by andy9 View Post
    Hello,
    Andy
    Hello Andy9
    Have you already learned a basic course of ABS programing?
    Feb 2017
    5
    Hello,
    I have not learned a basic course of ABS programming therefore its quite hard to get started. I found some examples from manual but they are bit hard to understand.
    Dec 2016
    9
    Hello,
    You must know that ABS may be gangerous for your machine if you make mistake.
    Is that option already activated on your machine?
    Feb 2017
    5
    I am not sure if the ABS is enabled or not. Is there a easy way to see if ABS is activated or not?
    Dec 2016
    9
    I dont know how to check it phisically but you can insert one ABS command for your regular program and see what the machine say.
    For example
    ABS: Z1 15 Y1 -15
    Feb 2017
    5
    Okey thanx, I will try it out on monday
    Dec 2016
    9
    So what is your result?
    Feb 2017
    5
    Quote Originally Posted by p2_lean View Post
    I tried to write ABS command and got error ´´No profile assignment after ABS-set´´ error explanation ´´define profile with instruction PRF XP YP
    May 2020
    Hi Guys, is anybody use StreaemBend S/W of Salvagnini, I have using it for 8 months now, I found it too hard to make ABS programming on. We had a basic training from the Salvagini guy, but due to it was new software, even he could not make ABS program on StreamBend S/W (strange), is any body has made ABS program on it?
  1. Radius bend - salvagnini
    By p2_lean in forum Bending, Forging, Extrusion...
    Last Post: 12-13-2016, 05:05 PM
  2. Salvagnini or Trumpf programmers
    By Independent CNC in forum Community Club House
    Last Post: 09-23-2013, 02:05 PM
  3. I need/tutor/assistance/programming/salvagnini
    By redford in forum Want To Buy...Need help!
    Last Post: 02-27-2009, 02:59 PM
