586,112 active members*
3,045 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Help! Stepper motors rough after computer replacement
    Aug 2010
    4
    Unhappy Help! Stepper motors rough after computer replacement
    The motherboard on the computer that runs Mach3 and my Microproto Microimill 2000 died, so I grabbed another computer from my boneyard (I'm a computer guy by trade), put in a new hard drive, a new parallel card (the old one was PCI and the new computer has no PCI slots) reinstalled XP and Mach3, put my old XML file in and thought I was good. But the stepper motors run rough, like they're filled with gravel. Since I haven't used the mill for nearly a year I disassembled it, cleaned out all the dirt and old grease, lubed it and put it back together, but the motors are still rough and uneven, with clicking and popping noises. With the motors off the feed screws turn smoothly.
    Thinking that it had to be the computer since that's all that I changed, I grabbed another old computer, this time one that has a PCI slot so I can use the original parallel card, installed Mach3 and my original XML mill file. No luck, the motors are still rough, both jogging and running Gcode..
    Since then I've tried everything I could think of but can't get the motors running smooth like they used to. And it's not just one stepper motor, it's all 3.
    But here's a kicker, with the Motor Tuning window open in Mach the motors run much, much better. But as soon as it's closed they're rough again.
    Some more info. The motors are Shanano Kenshi SST57D 1.8 degree per step, the mill feed screws are 20 threads per inch. I'm using 8000 steps per, 30 Velocity and 5 Acceleration. .
    I've been working on this for 3 days now with no success. Any suggestions would be appreciated.
    Oct 2015
    19
    Re: Help! Stepper motors rough after computer replacement
    I'm having a similar problem. Connecting usb directly to drivers and running motors they are perfectly smooth. Connecting thru controller and running mach 4 they stutter. I've tried every motor tuning configuration I can think of and get somewhat better results but the jerkiness or stuttering remains. I'm going down the computer route as well. Going to do a fresh install of win7 and hope for the best. If you do solve this. please post what fixed it.
    Oct 2015
    19
    Quote Originally Posted by hotrd717 View Post
    So I solved it. I saved my original OS and also made fresh win7 32bit OS. I was still having same and worse problems with new OS and mach 3.
    Definitely thought it was a com issue so I tried Ethernet connection on original win7 64 bit and viola, problem solved. I still don't understand the problem though. Updated usb drivers, the computer is maybe 5 years old, z68 Intel i5 and a very decent custom motherboard. I had also tried various usb cables.
    The upside is now motors run extremely smooth, quiet, and at very high speeds without missing. Some slight tuning onnz axis and I'm ready to make chips.
  1. Need some help please cnc computer replacement, now things aren't working right
    By foamcutter in forum Mach Software (ArtSoft software)
    Last Post: 05-07-2017, 11:18 PM
  2. Sinumerik 810M CRT replacement with Computer Screen
    By globalrobotics in forum CNC Machine Related Electronics
    Last Post: 02-07-2014, 07:54 AM
  3. Interfacing stepper motors with computer
    By John DiBernardo in forum CNC Machine Related Electronics
    Last Post: 06-01-2010, 03:19 PM
  4. Old Computer Controller Backup/Replacement
    By andrewr2 in forum Controller & Computer Solutions
    Last Post: 06-29-2009, 09:05 PM
  5. Stepper running Rough
    By dalescnc in forum Employment Opportunity
    Last Post: 05-04-2008, 09:30 AM
