586,036 active members*
3,654 visitors online*
Results 1 to 13 of 13
    Oct 2006
    37
    String serving machine
    I am hoping someone can help me. I want to drive two stepper motors from zero to 750 rpm together sycronized. I don't want to use a laptop. Is there a stand alone programmable driver that I can do this with? I would like to have a switch to turn them on and potentiometer that goes from zero to however fast I can get them.
    I bought this kit and thinking instead of Mach3 and my current drivers. Maybe there is some other driver I can use?
    【USA FREE】 2AXIS Wantai 1Axis Nema34 Stepper Motor 1700oz-in 151mm 6A CNC plase
    This machine will have a string stretched between the two motors and I want to wind another string around the one stretched between while the motors are turning. It's called serving. Making strings and cables for compound bows.
    Any help, I would greatly appreciate.
    Feb 2015
    123
    Re: String serving machine
    Maybe something like this will work for you....
    https://www.aliexpress.com/store/pro...711847030.html
    Rob
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Edit: fixed link.
    Dec 2013
    5717
    Any of these would work for what you want to do
    stepper motor speed controller | eBay
    Just wire the step & direction output to both drives' inputs, that will sync them.
    Oct 2006
    37
    thanks Jim
    I have been told they will only work with one motor/driver. I guess it is cheap enough to buy one and try it.
    Mar 2017
    23
    That's actually an interesting way of serving a bow string. I used to make these by hand myself and I could see that being a real help, if you can get the tension to stay.
    For your question, I personally would build a custom circuit to do this. As these steppers will only need to move one direction and at a constant set speed once adjusted.
    May I ask ehy steppers and not any other type of motor?
    After checking out Tim's option, if your not into building circuits, I'd definately try that out. For 20 bucks, I'd consider it worth a shot.
    Sent from my SM-G935V using Tapatalk
    Oct 2006
    37
    Specialty Archery is selling a machine with steppers right now. If you use any other motor, I think you would need a driveshaft to go all the way to the other side with some gears or cog belts to keep the timing.(you have to spin the string without getting twist in the string). That would be lot more moving parts, gears, bearings and supports. Steppers seem to be cheapest and can still keep the string from twisting. I am trying to program an Arduino, but having trouble getting the speed over 350rpms and it stalls. I'm thinking maybe getting mach3 and see how fast I can get them to go.
    it would be nice to have two programs. ONE- to turn on and off.....have potentiometer to control speed. TWO-have a counter to set how many turns then shut off, with potentiometer to control speed.
    I will settle for just turning it on and off for now and control speed with potentiometer.
    Quote Originally Posted by Clackneil View Post
    Mar 2017
    23
    Quote Originally Posted by dmh13433 View Post
    Let me see what i can cook up for you in the next few hours (ideawise, that is)
    Dec 2013
    5717
    Might also try one of these units. Can be programmed to run some number of turns then stop. I have one sitting on my test bench, but I havn't had time to play with it yet.
    SainSmart 1 Axis CNC Servo Stepper Motor Motion Programmable Controller, New, Fr | eBay
    Oct 2006
    37
    Jim, do you know for sure this will work? If you try it and it works, I think I would buy that. Does it only work if you input in how many turns?
    Dec 2013
    5717
    It has several modes of operation, I haven't really gotten too deep into it yet. I just bought it because I thought it was cool, and I might have a use for it one day. I have set it up on my test bench and played with it a bit. I know it will drive the motor some number of steps and speed that you program, and then by pushing another button it will reverse and go back to 0.
    This is from their product description ''Manual operation functions: position adjustments (manual jog speed and jog the number of steps can be set" So that function sounds like exactly what you need for your application.
    EDIT I found the manual for it http://www.variometrum.com/PDF/ST_PMC1_ENG.pdf
    Oct 2006
    37
    update on my project.
    I got everything built except a box to hold power supply, and drivers.
    Mach 3 is running the motors at 1,300RPM
    Here is a link to an archery forum showing it, and a link to youtube video.
    String Jig/Winder
    Nov 2018
    recurve bow string
    Any luck with getting motors to go above 1300RPM or any downside to doing so?
    Oct 2006
    37
    Quote Originally Posted by Tec22 View Post
    here is a video of my completed project. I had help from hfjbuis on cnczone with the program. The guy is amazing programing an Arduino.
    I only go 800 RPM. It will work faster, but not 1,300RPM I could probably go 1,000RPM. if you want to go much faster, I think you would need some gearing to step up the speed.
    https://www.youtube.com/watch?v=mWyiAOYC3QI
  1. Precision Machining Serving the East Coast
    By XactMFG in forum Manufacture Company Listing
    Last Post: 01-10-2017, 04:21 PM
  2. Cam-post string concatenation?
    By yar_seliva in forum Post Processors
    Last Post: 10-31-2013, 01:32 AM
  3. 18T dowload to pc no eob just long string
    By karlbushnell in forum Fanuc
    Last Post: 01-28-2011, 02:55 PM
  4. Zap String
    By Aplus in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2009, 05:01 AM
  5. Milling machine serving double duty as Plasma Cutter
    By nate in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-19-2008, 10:16 PM
