586,061 active members*
4,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > HELP - LATHE MOTOR BELT ROUTING
    Jun 2006
    5
    Hi Guys,
    I recently replaced my 2 belt on my NOS (almost sitting still since new) 2004 Bridegemill Lathe motor (the 560mm belts) by 3L240 ones as JT stated but upon reassembly I end up kinda mixed up over what belt goes over/under what idler...
    This is what I have right now - I DON'T KNOW IF IT IS OK
    The back belt (the one closer to the motor and enclosure wall) is going OVER the top idler (the one connected to the speed change lever) an OVER the bottom fixed idler.
    The front belt (the one closer to you) *is going UNDER the top idler (the one connected to the speed change lever) an UNDER the bottom fixed idler.
    Attachment 361780
    Attachment 361782
    Let me know if this is right or not please !!
    Thanks, Jason
    Apr 2015
    170
    Re: HELP - LATHE MOTOR BELT ROUTING
    The belt closest to the motor should go over the top of the lower roller alongside the other belt so that they run in the same direction and don't rub on the roller. Hope that helps.
    Aug 2011
    18
    Yep, you got it.
  1. Z Motor Belt 1:1 - Any reason for that???
    By Bob La Londe in forum DIY CNC Router Table Machines
    Last Post: 06-09-2012, 07:32 PM
  2. puma lathe belt
    By wrenchturner in forum Daewoo/Doosan
    Last Post: 04-16-2009, 05:01 AM
  3. Replies: 2
    Last Post: 04-12-2008, 06:16 PM
  4. Lathe belt help needed...
    By WilliamD in forum Uncategorised MetalWorking Machines
    Last Post: 11-22-2007, 06:39 PM
  5. should i belt my motor
    By Syphonics in forum Stepper Motors / Drives
    Last Post: 12-30-2006, 07:01 PM
