586,055 active members*
4,280 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Titanium swarf problem - re-posted in correct forum
    Aug 2014
    232
    Originally posted in Swiss Lathe forum by mistake. Sorry.
    I'm using a Maier to make parts from Ti6Al4V Grade 5 Titanium, but the swarf is causing me problems. One operation is a long 1:50 taper and the swarf wraps around the job, meaning I have to pause the job and manually remove the swarf before head 2 can take the job for the stock end operations.
    The finish I'm getting is really excellent, the tool inserts are those recommended for the job and they last well.
    I have tried various speeds and feeds, as well as positioning the coolant jets from all angles - no difference. I'm using normal suds, water based mix.
    A long google hunt produced a paper about using high pressure coolant accurately aimed into the cut, to force the swarf into a tighter curl and promote breakage.
    My machine doesn't have high pressure coolant, but I'm thinking about trying to rig up something. Have any of you guys tried this ? OR, is there another method of removing the swarf I have missed ?
    Zorbit.
    Jul 2018
    6339
    Re: Titanium swarf problem - re-posted in correct forum
    Hi Zorbit - have you heard of a chip breaker? Its a chunk of metal that lives behind the cutting tool that the string hits and its breaks the string? Peter
    Aug 2014
    232
    Hi Peter,
    Yes, I've used chipbreakers, most of the inserts I use have them built in, and I have added extras. I even made a tool that fits in the next tool position that deflects the swarf away from the job, with some, but not 100% success. The titanium swarf is too tough to break, it simply bends into even tighter curls.
    The most effective and current solution is to delegate swarf clearing duty to my assistant :-)
    Dec 2008
    3109
    Quote Originally Posted by Zorbit View Post
    Hi Peter,
    There is so many variables to consider...
    depth of cut... are you deep enough to allow the swarf to hit the chip breaker?
    RPM.... fast enough to drive the chip into the chip break channel
    Feedrate... high, to give a thicker chip so that any bending creates fracture which will create smaller chips
    Coolant supply... to stop work hardening of part, to chill swarf to allow fracture, to keep tool edge sharp
    dont allow tool to stop while on surface of material as this will wear out the cutting edge & work harden material
    It is good that you are doing a taper as this will vary the depth of cut and stop "notching" on the roughing tool cutting edge
    Aug 2014
    232
    Hi Superman,
    Thanks for replying. I run this job on a sliding head "Swiss" type lathe, so I only get one pass to cut the taper from nearly bar size at 8mm to the small end, the depth of cut varies a lot over the length of the taper but often the swarf doesn't break at all. If I run without flood coolant the swarf is orange in an instant.
    I do get some notching on the tool, at a point where the bar diameter is when depth of cut is deepest. A strange effect that doesn't happen with any other metal I use, but it's slow and not a big deal.
    Cheers,
    Z
  1. Titanium swarf wraps around job - interferes with head 2
    By Zorbit in forum CNC Swiss Screw Machines
    Last Post: 05-13-2017, 10:49 AM
  2. Need correct RPM and feed rate for 1" spade drill, drilling titanium
    By leoliver in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2016, 10:08 AM
  3. Posted on Bobcad Forum - Help with Upgrade v23
    By bill south in forum BobCad-Cam
    Last Post: 12-12-2009, 09:39 PM
  4. Bridgeport lathe problem,is this the correct forum?
    By hdjeffrey in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2009, 09:22 AM
