Anyone ever considered making a small Siemens-Martin furnace? It is a regenerative furnace which basically means you use a heat exchanger to extract heat from the exhaust gas and use it to heat the inlet air prior to combustion. The temperatures get as high as 17-1800 degC, enough to melt steel.
John
