586,069 active members*
3,341 visitors online*
Results 1 to 10 of 10
    May 2012
    114
    Servos for pro4896
    So. If someone were to hypothetically be replacing their nema 34 960oz in steppers from cncrp with servos, what should the kw rating be?
    Re: Servos for pro4896
    Do you have the 2:1, or 3:1 reduction? And what speed are your rapids set to.
    And what kind of servos?
    At 1000 rpm, you're 960oz steppers have about 200oz of torque.
    A 200w AC servo has about 250oz of peak torque, all the way to 3000rpm. If you went with a 10:1 gearbox, you'd have much more power with the 200w servo. If you want to keep the existing belt drive, then you'd probably want a bigger servo.
    Jul 2015
    33
    Newbie here with a CNCRP machine on order - can you explain why you would do this (steppers -> servos)?
    May 2012
    114
    Link to the servos.
    http://dmm-tech.com/Files/ACSMTR-G1-0815A15B.pdf
    I'll be keeping the 3.2:1 reduction.
    May 2012
    114
    Steppers will eventually burn you. They loose steps. They heat up nicely on long jobs. Inefficient. Noisy. And the list goes on.
    I lost a 5 hour 3d carve yesterday because of them. So hi ho.. ho ho.... off to servos I go.
    Quote Originally Posted by Ctbjdm View Post
    Not if the machine is setup properly, or you don't try to go faster than the steppers are capable of.
    With 3:1, I'd probably go with the 750 watt. If you could go 6:1 or higher, you'd get the same or better performance from 400 watt..
    750w have ~980oz-in peak torque, which would give you about 5x the power at higher rpm.
    400w would probably give similar performance to what you have now.
    24221
    I use servo's exclusively, the plus for me is the closed loop aspect, as well as current only when demanded.
    Al.
    Albert E.
    May 2011
    790
    Quote Originally Posted by ericclinedinst View Post
    Read through this thread:
    http://www.cnczone.com/forums/diy-cn...ter-build.html
    Apr 2009
    5516
    That 960in-oz stepper at 1000rpm and 200oz-in of torque is producing around 150W of power. The 400W servo will produce 150W of power continuous and about 450W peak at 1126rpm (1768ipm) (and 1.2kW peak at 3000rpm). I have my doubts as to whether the mechanicals can handle the power. Or, you're limiting the speed at which you run the servo, which would probably be a waste of the servo's capability (meaning money.) In other words, the drive ratio as set up (2:1) does not lend itself well for servos. I think an easy-servo or step-servo system would work better (or an expensive direct-drive servo).
    I think a better approach would be to simply change the drive ratio to 3:1 or 4:1 first, and see if the problem persists. Remember the pinion acts as a gear increaser or multiplier, so your 2:1 ratio is negated by the 3.1416 pitch circumference, giving you an effective gear ratio of 2/pi or .6366 motor turn per 1". Or in other words, you're getting 2/3 motor torque at the load.
    Sep 2019
    44
    @ericclinedinst:
    Did you replace the steppers with servos?If yes what is your experience?
    Br,
    David
  1. Pro4896 build finished in NY
    By Blisswoodshop in forum Avid CNC
    Last Post: 04-23-2017, 12:51 AM
  2. Another PRO4896 Begins...
    By DaveCNCnewb in forum Avid CNC
    Last Post: 11-09-2016, 01:37 AM
  3. The PRO4896
    By CrockettCNC in forum Avid CNC
    Last Post: 03-25-2016, 02:16 AM
  4. CRP PRO4896 NEMA 34
    By HDTHEATER in forum Avid CNC
    Last Post: 05-27-2015, 01:39 AM
  5. PRO4896 in Northern VA
    By bdn103 in forum Avid CNC
    Last Post: 04-17-2014, 07:56 PM
