586,105 active members*
3,320 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > HSMExpress - simple task
    Jul 2006
    23
    I am trying to get the hang of HSMExpress. I've gone through the two 2.5d tutorials which are included, now I'm trying to apply what I've learned to a real part.
    I can't figure out how to machine the notch in the front of the part in the image. It seems like such a simple task and would only take minutes to program manually, but no matter what I try I can't get it to work properly. Unfortunately I won't have access to SolidWorks/HSMExpress over the weekend, so I'm hoping somebody can at least point me in the right direction for when I get back to work Tuesday morning. What milling strategy do I use, and what edges or faces do I select for the geometry? I need to approach from the side so I can use CDC.
    Is there a way to manually create or edit the tool paths?
    Also, is it possible to mill the angle with a ballnose in Express, or would I need Works?
    Attachment 362654
    Here is the basic finish tool path for the notch. Yes, this is what I'm stuck on! It should be so simple, but everything I try seems to only work with a closed tool path.
    Jul 2006
    23
    Re: HSMExpress - simple task
    I figured it out. 2D contouring, I just had to uncheck "Propagate along Z". It's the simple things that get you hung up!
    I still need to figure out how to cut the angle with a ball end mill. Can it be done with Express?
    Feb 2009
    311
    Quote Originally Posted by Jester966 View Post
    It is possible by using the trace tool path and a manually created line that puts the ball mill tangent to the face to cut. Something like this:
    Attachment 362772
    Then you put that single trace operation into a linear pattern using one of the chamfer edges as the guide.
    Attachment 362774
    C|
    May 2017
    edit: deleted, accidentally replied to solved post (chair)
  1. Replies: 6
    Last Post: 12-27-2017, 05:30 PM
  2. HSMExpress to HSM Works
    By Toolslinger in forum Autodesk CAM
    Last Post: 04-05-2017, 08:38 PM
  3. Mach3 and gcode from HSMexpress
    By zerodegreec in forum Mach Mill
    Last Post: 01-22-2013, 05:01 PM
  4. simple task attempt limited success
    By George777 in forum Mastercam
    Last Post: 08-04-2008, 05:17 AM
