Hey Guys,
First time post here! I'm hopeful you all will be able to help me out.
We have a HAAS TL2 at work. I wrote a program that runs a G71 canned cycle. The program runs fine without tool nose compensation. However, when I plug in a G42 for TNC, the G71 cycle stops at the end of the last "finish" pass. I get HAAS error code 369: Tool Too Big. The strange thing is, the contour that the error code comes up on is the very last outside contour. How is it possible for the tool to be too big for an outside contour?
Attached is the picture of the geometry, and below are the tabulated values.
Any help or ideas is greatly appreciated. Thank you for your time.
(GEOMETRY INPUT) (D1 = 0.75") (D2 = 1.25") (FACE LENGTH = 1.0001") (FACE OFF = 0") (EDGE 1 = 0.0625 RADIUS") (EDGE 2 = 0.125 RADIUS") (EDGE 3 = 0.0625 RADIUS") (SPINDLE STICK OUT = 0.5") (TOTAL STICK OUT = 1.6251")
Below is the section of G-Code with TNC issues:
N300 (SHIFT G54 WORK COORDINATES Z-ZERO = FACED END) (ROUGH TURN PART) G10 L2 P1 G90 X0. Z1.5626 (SET G54 TO X0. Z1.5626) (Z-ZERO IS THE FINISHED FACE) G00 G28 U0. (HOME OUT TURRET) G00 T101 (OD RGH TURN TOOL) G97 S1000 M3 (CANCEL CSS, START SPINDLE FWD) G54 (G54 WORK OFFSET) G42 (TNC = ON) G00 Z0.05 (Z START POINT OF CANNED CYCLE) G00 X1.35 (X START POINT OF CANNED CYCLE) M08 (TURN ON COOLANT) G50 S1800 (SET MAX RPM) G96 S350 (CONSTANT SURFACE FOOTAGE) G71 P301 Q302 D0.06 U0.04 W0.02 F0.007 (SEQ.#'S/CUT-DEPTH/X-LEFT/Z-LEFT/FEED) N301 G00 X0.625 (SMALLEST DIAM.) G00 X0.625 Z0. (MOVE TO FACE) G03 X0.75 Z-0.0625 R0.0625 (EDGE 1 END PT.) G01 X0.75 Z-0.8751 (FACE CUT) G02 X1 Z-1.0001 R0.125 (EDGE 2 END PT.) G01 X1.125 Z-1.0001 (SHOULDER LRGST DIAM.) G03 X1.25 Z-1.0626 R0.0625 (EDGE 3 END PT.) N302 G00 Z0.05 (Z START POINT) G00 X1.35 (X START POINT) M09 (TURN OFF COOLANT) G40 (TNC = OFF)
Best regards,
Bennett
