586,102 active members*
2,394 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > diy cnc cuts to big when 6mm depth. but 3mm depth it cuts perfect.
Results 1 to 8 of 8
    May 2017
    4
    hello,
    i have build my own cnc machine. when i cut a square 200mm x 200mm wood, and i cut it with 3mm depth per go. it cuts perfect.
    but when i try the same square but then cut is 6mm depth in one go it is 1mm to big. on the x and y axis.
    i use universal gcode sender.
    does any of you guys have an idea?
    sorry for my bad english.
    Jun 2010
    4256
    Re: diy cnc cuts to big when 6mm depth. but 3mm depth it cuts perfect.
    It may be that cutting 6 mm deep draws more power/current (than 3 mm), which creates more noise on the motor control lines. Solving noise problems is an arcane art.
    Cheers
    Roger
    May 2017
    4
    [QUOTE=RCaffin;2047762]It may be that cutting 6 mm deep draws more power/current (than 3 mm), which creates more noise on the motor control lines. Solving noise problems is an arcane art.
    Cheers
    Hello, thanks for the reply.
    Solving noise problems is there a way to do this?
    Is it changing some grbl like settings?
    And yes, with ones?
    Thank you
    Jun 2010
    4256
    Yes, of course, but even experts can be tearing their hair out.
    You may need to find some teenage electronics hacker for this. He will need to be fairly experienced. It is not something which can be explained over the web.
    Sorry - I did say it can be extremely difficult!
    Cheers
    Roger
    Feb 2006
    210
    Check your rigidity and backlash. At 6 mm the forces on the bit are at least double those at 3mm and it could be distorting the entire machine.
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    May 2017
    4
    [QUOTE=beone;2047792]Check your rigidity and backlash. At 6 mm the forces on the bit are at least double those at 3mm and it could be distorting the entire machine.
    Hello Dave,
    The machine is pretty strong. But if it is not as strong as I think would it not make the square smaller and out of shape? And not bigger?
    Greetings
    Jun 2010
    4256
    Normally, but strange things can happen.
    Research time.
    Cut some squares at varying depths (1,2,3,4,5,6 mm) and see what the errors look like.
    Cut some squares 50, 100, 150, 200 mm square at 3 mm and 6 mm depth and see what the errors look like.
    When you cut a square 200 x 200 mm at 6 mm depth, does the spindle return to exactly 0,0 at the end, or is it off?
    Each test will tell you something useful.
    Cheers
    Roger
    May 2017
    4
    [QUOTE=RCaffin;2048802]would it not make the square smaller and out of shape?
    Research time.
    Cheers
    I Wil try this. Next week. I have no time this week.
    When I did it I Wil post again.
  1. Diffrent cuts depth
    By takamin in forum PhotoVCarve and VCarve Pro
    Last Post: 05-09-2015, 11:22 PM
  2. Depth of Cuts
    By Mattyvdv in forum MetalWork Discussion
    Last Post: 08-01-2014, 03:00 PM
  3. Feeds and depth of roughing cuts:
    By ruawake in forum Tormach Personal CNC Mill
    Last Post: 04-08-2013, 08:16 PM
  4. Typical Depth of Cuts for steel
    By Palinvan in forum Taig Mills / Lathes
    Last Post: 08-04-2012, 01:11 AM
  5. MCX depth cuts question
    By charper in forum Mastercam
    Last Post: 02-07-2007, 05:46 AM
