586,077 active members*
3,968 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori-Seiki MV35/40 retrofit with LinuxCNC
Results 1 to 3 of 3
    Sep 2010
    ok, I've taken the ancient Fanuc M5 (or M6?) control off, and am down to the drives. LinuxCNC is installed with a 6i25 and 7I77 setup and ready to go........
    The axis drives are Fanuc A20B-0009-0320, coupled to a A06B-0651-B 012 2500M Fanuc yellow cap 10M DC servo motor. I have the connector pinouts sorted out and down pat (I think) and ready to hook up, Looking at the motor it appears to have an internal 2500 cpr encoder mounted directly on the motor shaft - all well and good, except the drive expects to see a tach input, normally mounted on the motor, but in this case provided by the Fanuc control through some type of encoder-to-virtual-tach chip. I've been reading that a lot of those controls can be set to torque mode, and doing away with the tach input (as opposed to velocity mode) by moving a jumper, but seems my google-fu skills come up short, as I can't find anything on this drive being able to do that.
    Anyone know how to change this drive to torque mode? Or isn't that possible?
    Any ideas?
    Re: Mori-Seiki MV35/40 retrofit with LinuxCNC
    I used to retrofit some MORI SEIKI and OKUMA with Fanuc system. What i did was connect the encoder feedback to the new CNC controller. You don't need to change anything on the drive, just connect the 0~10V analog signal from CNC to the old FANUC drive. Email me if you need help, [email protected]
    Sep 2010
    I was able to generate the virtual tach signal with LinuxCNC, seems to work fairly well......
  1. Mori Seiki MV35/40 Axis Interlocks
    By danl715 in forum Mori Seiki Software
    Last Post: 08-15-2017, 01:19 PM
  2. Mori Seiki MV35/35 manual
    By JETMetalWorks in forum DNC Problems and Solutions
    Last Post: 09-01-2014, 03:40 PM
  3. mori seiki MV35 FANUC 11m 1986
    By zavateandu in forum Mori Seiki Mills
    Last Post: 03-29-2013, 09:23 AM
  4. Mori Seiki MV35/40 Fanuc 11M
    By fmaw44 in forum Mori Seiki Mills
    Last Post: 09-25-2012, 07:52 PM
  5. Mori Seiki MV35/35 MX1
    By jdeere4250 in forum Mori Seiki Mills
    Last Post: 04-30-2012, 06:03 AM
