i have a 3040, I'm using uccnc and vcarve.
i have a simple project which involves cutting a 12mm pocket at each corner of a board, I'm using a 6mm bit.
if I cut : bottom left, top left, bottom right, top right everything is fine.
if I cut : bottom left, top left, top right, bottom right then the two right hand holes are approx 5/6mm too high.
it seems to me, that when making a diagonal move where the X axis goes a long way and the Y axis only a short way (from the top of one pocket to the centre of the next) the Y axis is either not moving or not moving accurately. I can feel the Y axis stepper slowly doing something but clearly not enough.
by going top left to bottom right the y axis is moving a similar amount to x and has no issues.
anyone have any ideas on whether this is sensible and what I might do from a hardware or software perspective to fix?
Dan
