My spindle is on output 2 and vac is output 1 pin 17 but I can not seem to get them both to tun on when my spindle starts up. ???
Most people use the mist or flood commands to turn on their dust collectors, and use M7 or M8 in their g-code to do it.
Why not pick the Vac up with the outputs on the VFD, or if a Router use a auxiliary contact on a relay if used?
Al.
Albert E.
