Just wondering how many people run more then one machine? I started a new job and I'm running two cnc lathes, with the set up time, inspection time and the short cycle times plus all the paper work, this seems to waste more then gain, the machines sit idle alot. On the mills its no problem as the cycle times are 7-8 hrs not 3-15 minutes. the last place I worked I would set up the machine and then put a operator on it and I would set up another machine, this worked good. just want to see if anybody has been through this crazy waste of time. thanks
