586,089 active members*
3,836 visitors online*
    Feb 2016
    4
    Problem Hitachi Seiki VA-40
    Hello, I have a problem with hitachi seiki VA-40, the system does not start, I start the machine, the screen indicates system not started, I start the system but the servo amplifier of the "Y" axis is alarm, the alarm is HCAL, I already did tests of conecting The U, V and W power supply and is not alarmed, could anyone help me? please
    Dec 2009
    539
    Re: Problem Hitachi Seiki VA-40
    It will either be the cable is shorted out, the motor is shorted out or the main transistors of the servo went bad - what is the control and what model of servos are they?
    John
    Feb 2016
    4
    John
    the control is 6M and the servo drive is A06B-6047-H003, I changed the transistors and the machine worked a few months, but the last week the same problem occurred, try to change the PCB to another drive and lit the same alarm, it colud be the PCB? or something in this?
    Thank you
    Dec 2009
    539
    If the alarm is following then it is something in the servo. They are not too expensive so best bet is to swap the whole unit. I could be a combination of items causing it to fault
    John
  1. ATC problem with Hitachi Seiki VA35
    By andy.f in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2013, 12:30 AM
  2. hitachi seiki parameter problem
    By kurt_laughton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2011, 06:31 AM
  3. Problem Hitachi Seiki HT 40G
    By rpt973 in forum MetalWork Discussion
    Last Post: 08-19-2011, 11:01 PM
  4. Problem Hitachi Seiki HTG 40
    Last Post: 07-07-2009, 10:37 PM
  5. Hitachi Seiki HT-20 Threading problem
    By wiks in forum MetalWork Discussion
    Last Post: 10-14-2008, 07:18 PM
