How can I connect my Deckel Maho DMC103V to PC/Laptop so I can transfer programs into a machine?
I was looking around in the internet and there are a couple of ways in general for CNC machines, but I don't know which will work for my machine.
Yes and PC/Laptop dont have anymore RS232 ports what can i use to connect them ?
If you want to use RS232 you will need a USB to RS232 converter cable.
usb to rs-232 db9 serial converter | eBay
I would just use the network connection and plug the 103 into your router. The network cable is inside the electrical cabinet on the left side. IF it's like my 103's.
Machine looks like this in pic https://image.prntscr.com/image/5148...7a00264fa7.png
In Heidenhian (Millplus IT) you can use CDS Lite and a networks connection. Its super simple to set up. I found the CDS lite on one of the CD's that came with the machine.
This combo is super fast and allows you to pull the Machine constants, tool tables ect right off the machine and store them for back up on your PC, as well as transfer massive programs onto the controller.
help me please regarding cdslite connection to millplus grundig check jpeg for more details about my controller.i connect machine to my laptop with RJ45 connector ..machine ip is 192.168.0.57 ..check connectivity thru ping from laptop which reply positive...then
i have install cdslite with this configuration see jpeg...but no success..please guide me where i am doing wrong
regards
asif
If you're using the network to communicate with the machine your settings are wrong. Compare your picture #2 to the picture I've attached .........
Attachment 401030
Good Luck
Dear all
I need docs and manuals related to
DECKEL MAHO DMC103V and DMC 63.
E-mail [email protected]
Many thanks in advance.
