586,065 active members*
4,469 visitors online*
Results 1 to 11 of 11
    May 2017
    Question Deckel Maho DMC 103V connect to PC
    How can I connect my Deckel Maho DMC103V to PC/Laptop so I can transfer programs into a machine?
    I was looking around in the internet and there are a couple of ways in general for CNC machines, but I don't know which will work for my machine.
    Mar 2007
    64
    Re: Deckel Maho DMC 103V connect to PC
    Quote Originally Posted by Cy4 View Post
    What control does your machine have? If it is a Siemens there is a network connection and 2 RS232 ports. You can use any of them to transfer programs. We use the network connection.
    If the control is a Heidenhain control there is network connections and RS232.
    May 2017
    Yes and PC/Laptop dont have anymore RS232 ports what can i use to connect them ?
    Mar 2007
    64
    If you want to use RS232 you will need a USB to RS232 converter cable.
    usb to rs-232 db9 serial converter | eBay
    I would just use the network connection and plug the 103 into your router. The network cable is inside the electrical cabinet on the left side. IF it's like my 103's.
    May 2017
    Mar 2007
    64
    Take a look at the picture it should help you locate the network cable.
    send me an email address and i'll send the picture to you full size
    Oct 2010
    6
    In Heidenhian (Millplus IT) you can use CDS Lite and a networks connection. Its super simple to set up. I found the CDS lite on one of the CD's that came with the machine.
    This combo is super fast and allows you to pull the Machine constants, tool tables ect right off the machine and store them for back up on your PC, as well as transfer massive programs onto the controller.
    Aug 2007
    224
    help me please regarding cdslite connection to millplus grundig check jpeg for more details about my controller.i connect machine to my laptop with RJ45 connector ..machine ip is 192.168.0.57 ..check connectivity thru ping from laptop which reply positive...then
    i have install cdslite with this configuration see jpeg...but no success..please guide me where i am doing wrong
    regards
    asif
    Mar 2007
    64
    If you're using the network to communicate with the machine your settings are wrong. Compare your picture #2 to the picture I've attached .........
    Attachment 401030
    Good Luck
    Aug 2007
    224
    Quote Originally Posted by cncmm View Post
    Attachment 401030
    Good Luck
    Not using network right now but machine directly connected to pc thru Rj45 connector... machine ip is 192.168.0.57
    Now please confirm me that i use that setting which mention in ur picture...or something else..
    Regards
    Asif
    Apr 2022
    Dear all
    I need docs and manuals related to
    DECKEL MAHO DMC103V and DMC 63.
    E-mail [email protected]
    Many thanks in advance.
  1. deckel maho dmu 50 t
    By gunz in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-24-2021, 01:54 PM
  2. Deckel Maho DMC 103v
    By nash in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-05-2019, 08:41 AM
  3. Deckel Maho DMU 50 VL
    By waltteris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-13-2016, 09:32 PM
  4. Deckel maho mh500c
    By gaherne in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-20-2010, 12:38 PM
