Hi there,
The new lead option (as well as others) in the profile command are fantastic, but I have a part in which MadCAM is attempting to start the lead at the lowest point, then go up, and then back down. I can work around this but simply specifying an entry angle, but wanted to document this problem. It does not seem to do this on closed curves and worked out brilliantly on some test cuts I made with it yesterday.
Many thanks,
O
