586,635 active members*
3,564 visitors online*
Thread: Concrete VMC
Page 8 of 16 678910
Results 141 to 160 of 305
  1. #141
    May 2008
    1185
    Re: Concrete VMC
    Looking rather nice.
    Is the head two pieces for tramming?
    youtube videos of the G0704 under the name arizonavideo99
  2. #142
    May 2016
    108
    Re: Concrete VMC
    Yes the head is made out of two pieces. The gap between the 2 parts will be epoxy filled same as i gone tram my column.
    Head is now welded and this evening i machined the spindle bracket. The main block is now also epoxy filled.
    Plan is to have this all mounted on the column coming weekend.
    Stef
  3. #143
    Mar 2014
    1131
    Re: Concrete VMC
    Unbelievable. Now I understand why you choose that giant servo.
  4. #144
    Sep 2005
    1740
    Re: Concrete VMC
    So your building a Milling machine with a router motor for a spindle? The project is interesting but whats the point?
  5. #145
    Aug 2013
    189
    Re: Concrete VMC
    Quote Originally Posted by wmgeorge View Post
    you must be confused... he's using a 3.7KW spindle servo motor 12k RPM (should weight about 40kg) + BT30 spindle unit, that's not a router motor... might not be the most powerful motor in the game but for what I see Tormachs 1100 doing with a 1.1KW motor I say he will be pretty well served...
    you're getting closer and closer Stef, I should be starting my molds very very soon, just received the epoxy last week and got the sand yesterday... Now I need to buy some steel and wood for the molds... anyday now...
    how much does that head weight? just the structure not with the motor and spindle...
    best regards and keep the great work!
  6. #146
    Sep 2005
    1740
    Re: Concrete VMC
    Quote Originally Posted by vakeiros View Post
    k!
    Not confused except about the purpose of the build? He is using a high speed spindle motor for a milling machine or a router? Which is it. A milling machine is much different from what he is building, so it must be a router?
    But this is a Tormach, (a milling machine) he is a long ways from that, https://www.tormach.com/store/index....00&portrelay=1
  7. #147
    May 2016
    108
    So a haas milling machine with a 12krpm spindle is in your opinion also a router?
  8. #148
    Oct 2017
    12
    Re: Concrete VMC
    Quote Originally Posted by stef110 View Post
    I also am very confused, because I have been made to believe that a milling machine should have a spindle capable of 10-12krpm. Where as a router typically has a max spindle speed of about 20krpm. My machine is also a cast build, with a heavy spindle head, and will also employ a 3.8kw spindle drive capable of 10-12krpm.
    Aluminum as I understand it cuts best on 2 flute bits at ranges of 8-10krpm. So wouldn't this be a perfectly acceptable spindle motor speed?
  9. #149
    Sep 2005
    1740
    Re: Concrete VMC
    Yes I am still confused because the CNC conversion on a milling machine I did, I could control motor speed down low enough for tapping and reversing the tap to back out. Peck drilling and etc all at less than 50 rpm, so I had no use for a Spindle that could run 12,000 rpm because I did very little aluminum milling. If he can not run at those low speeds needed, its a router. Well built nice looking, router not to be confused with a commercial CNC machine for milling.
  10. #150
    May 2016
    108
    Re: Concrete VMC
    @ wmgeorge
    There is a servo that will spin the spindle. so every rpm from 0 to 12krpm is possible including positional movements. So i think this build is definitely not classified as a router.
    @ vakeiros
    The weight of the steel parts is 50kg. totalweight of the head is approx 120kg in total.
    50 kg steel
    9 kg epoxy
    37 kg servo
    16 kg spindle
    5 kg atc
    Stef
  11. #151
    Jul 2012
    102
    Re: Concrete VMC
    Who ever said his spindle can't run at low rpms? It's a servomotor, it can run at 1rpm if he wants to.
  12. #152
    Sep 2005
    1740
    Re: Concrete VMC
    Quote Originally Posted by jackjr-123 View Post
    So whats the torque when running at say 10 rpm? So the spindle head posted, a BT30 the fastest speed I could find for sale, is rated at 8,000 rpm?
    https://www.ebay.com/i/223568416744?...SABEgIX4_D_BwE
    lts going to be interesting to see how it turns out and what use he finds for it when done. Considering for the time and money he has invested in it, he could have had a commercial CNC milling machine making parts long ago.
  13. #153
    Jul 2012
    102
    Re: Concrete VMC
    He will get the rated motor torque (probably around 10-12 Nm for a 3.7kW motor) at 0 rpm up to several thousands rpms (2000-3000 rpms), and it will decrease from there.
    The spindle will go as fast as its bearings allow. The taper as nothing to do with it. There are plenty of 24k+ rpms BT30 spindles.
  14. #154
    Aug 2013
    189
    Re: Concrete VMC
    My version is the 5.5KW and it's rated torque 26Nm from 0-2000 RPM and going down from there, so he's version is 3.7kW should be in the 15's Nm at least 0-2000RPM, and he will be able to make rigid taping up to 2000RPM so yeah... this is quite a router
    if you see the whole build he decided to go with the 12krpm considering to get a new spindle unit in the future since his version is 8Krpm max if I recall correctly. these motors are MONSTERS
    PS. these motors support overdriving up to 30min, they supply a 5.5Kw driver with the 3.7Kw motor so it can produce 5.5Kw up to 30min without problems, it's factory ensured to work this way so those big facemill ops, and more exigent taping and drilling won't be a problem.
    yes he could get a commercial machine for lots of more money, and without the thrill of making it himself.
    exactly like me, I'm starting a build somehow like this one perhaps a bit bigger, so far I spent close to 12000€ and I just need to spend 4-500€ more to get all I need, including 16 tool ATC, controller, servo motors, spindle motor, drivers, and measuring tools (indicator, granite straight edge, and many other stuff), so let's say it will end at 13000€, I'd look for commercial machines and found nothing lower than 25000€ + import taxes that would be in the 30% range here in Portugal,and travels wouldn't be as large as the machine I'm making and linear motion also not as good as I'm using, spindle not as fast. so yeah I'll be taking time to make the machine of course I am but what about the experience of making the damn thing? and all we learn??? It's great building our stuff... I don't mind spending 2 months of free time to build the machine while not spending about 20000€... after all I'll never spend 20000€ worth of time building the machine... this is about me, and I'm almost sure it's the same for everyone who makes a project like this one.
    So congrats on your work Stef, keep it coming, I'm really enjoying your build!
  15. #155
    Sep 2005
    1740
    Re: Concrete VMC
    If I am doing the math right 12 Nm is only around 8 or 9 ft lbs. Does the spindle have reduction gearing? I would guess not. The one (BT30) I posted off eBay had an 8,000 rpm (bearing) rating and it was $300 USD.
    Added: Yes you two are certainly talented and I admire your skills at machining. Good luck.
  16. #156
    Aug 2009
    291
    Re: Concrete VMC
    Stef
    Filling the gap while it's mounted or via the leveling technique you used on the bed?
    And another way to look at wm's question is are there specific projects/products you have in mind?
  17. #157
    May 2016
    108
    Re: Concrete VMC
    Fill the gap once i trammed the head with the gub screws.
    No special projects in mind for this machine its an replacement / upgrade for my current g0704 mill. I use the mill mostly for hobby purpose and some small jobs. Mostly robot / battlebots related machining.
  18. #158
    Sep 2005
    1740
    Re: Concrete VMC
    It would be interesting to see a couple of your Battlebots.
  19. #159
    Mar 2017
    411
    Re: Concrete VMC
    Here is one in post #7
    https://www.cnczone.com/forums/verti...ml#post2054102
  20. #160
    May 2016
    108
    Re: Concrete VMC
    I have been on last year series (2018) with team reality a dutch team. I normally build the smaller machines like max 13.6 Kg
    Im the second guy from the left.
    This machine i have build last year with my own team for a competition in Shanghai its a air powered flipper robot to shoot your opponent out of the arena. Its a complete custom build pneumatic system the only thing thats a factory part is the high pressure air regulator to transform the 200bar to only 30bar weapon pressure.
    https://www.youtube.com/watch?v=0O8qj1NAFAc
    All parts have been machined on my 3 axis g0704 and with an manual lathe.
    Stef
Page 8 of 16 678910
  1. Using concrete as a fixture
    By GITRDUN in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-30-2015, 09:17 PM
  2. Concrete Stamp....
    By AussieGecko in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2013, 01:25 PM
  3. Replies: 0
    Last Post: 11-28-2012, 06:39 PM
  4. Concrete Lathe
    By tusavision in forum Linear and Rotary Motion
    Last Post: 01-18-2010, 01:26 AM
  5. Polymer Concrete
    By ericdwilso in forum Vertical Mill, Lathe Project Log
    Last Post: 11-13-2006, 06:22 PM
