586,106 active members*
2,987 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > PROBLEM BRU 500 AND BRU 200 SETTINGS OR TUNNIG
    Feb 2014
    Dear friends
    i have a INTERMAC 1500 glass 4 axis router.The machine is using a OSAI 10 controller and the motors and the drivers are the bru 500 and the bru 200 from Reliance Electric
    I try to retrofit the machine and intend to use linux cnc and mesa analog card .I have problem with the motors When i enable the motors they are rotate with stable small velocity CCW
    I don't believe that i can tune them because in the user manual of the driver https://www.axcontrol.com/pdfs/bru-500.pdf for communicate with the motors a certain program called ECC PROG is needed and i can not find it
    if anyone have any suggestion for this problem
    thanks
    Yannis
    Jun 2003
    866
    Re: PROBLEM BRU 500 AND BRU 200 SETTINGS OR TUNNIG
    I think you just need a VT100 terminal emulator. The drives were meant to interface to a Tandy portable computer that emulated the VT52 terminal.
    It's usually a little annoying to get the cables set up right, but you don't need a special program.
  1. I bought a CNC Milling Machine 3020T/ settings problem maybe.
    By poolrod2 in forum CNC Machining Centers
    Last Post: 09-22-2016, 04:48 AM
  2. problem with mastercam x6 using the serial port settings
    By functionbikes in forum Mastercam
    Last Post: 08-10-2012, 11:18 PM
  3. re : settings
    By Gary Cooper in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2012, 09:55 PM
  4. cv settings
    By electric2u in forum Machines running Mach Software
    Last Post: 01-27-2011, 03:19 AM
  5. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
