586,094 active members*
4,116 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Y axis squeaks in one direction
Results 1 to 3 of 3
    Jul 2008
    12
    I have a Summit VS242B CNC knee mill. Today, when I started it up, there is a noticeable "squeak" only when I move the Y axis towards me. It squeaks when I move the Y axis manually also. There does not seem to be any drag on the axis. Any suggestions?
    Apr 2004
    5737
    Re: Y axis squeaks in one direction
    Check the coupler that connects the Y axis motor to the screw; it sounds like it might be loose.
    Andrew Werby
    Website
    Jul 2008
    12
    Thanks for the info Andrew. I will check it out
  1. Z axis direction
    By red2002 in forum EdingCNC
    Last Post: 04-28-2016, 11:41 PM
  2. Y AXIS WRONG DIRECTION
    By cncbeastmaster in forum Haas Mills
    Last Post: 11-24-2014, 05:21 PM
  3. New 4th axis one direction only
    By speedtwin69 in forum Taig Mills / Lathes
    Last Post: 11-22-2012, 04:39 PM
  4. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  5. C axis direction
    By riverking in forum Daewoo/Doosan
    Last Post: 12-09-2009, 01:38 AM
