586,071 active members*
3,944 visitors online*
Thread: FLA 4x4 Kit
    May 2017
    FLA 4x4 Kit
    Greetings everyone. I'm Dennis located in central US.
    This is my first post here so I'll try not to mess it up too bad. I've enjoyed reading through all the interesting threads here.
    My build has been going pretty good so far despite the lack of updated diagrams/videos covering all the design changes. However, a little patience and common sense and the pieces are coming together.
    Now for the reason for my post. My problem is with the Linear Motion Carriages. In all of the diagrams I've seen and in the video, there are 6 bearings on each carriage. My carriages only have 4 bearings each. I don't see how they can run true on the rails without the other two bearings that go in the slots at the ends of the carriages and run along the edges of the rails.
    This is especially true for the top carriage on the X axis rail. I'll try to include pics to show what I mean. There will be a lot of weight on this carriage and as you can see in the pics (with no weight at all) it already drops to the point where it will drag on the extrution behind the rail.
    If this is a design change and I'm just doing something wrong, I'd be eternally grateful for any help in understanding how to do it.
    In total I beleive I am missing 12 bearings (2 bearings on each of 6 carriages).
    Thank you for your time,
    Dennis
    Re: FLA 4x4 Kit
    There should be six bearings total. I will get the others out to you immediately.
    Fine Line Automation
    www.finelineautomation.com
    May 2017
    8
    Re: FLA 4x4 Kit
    Hey mate,
    For your controller, I highly recommend the MASSO CNC controller. Dedicated hardware and no need for a PC.
    Right now you can also get some free homing sensors with your order. Just head over to Home - Hind Technology Group
    Let me know if you have any questions,
    Ben
    May 2017
    Re: FLA 4x4 Kit
    Quote Originally Posted by FineLineAuto View Post
    Thanks Nate!
